DigitalJoe
Flight distance : 504688 ft
I just received my Command Unit today. Attached it and booted up the system with my Canon 5d Mark IV and a Canon 20mm lens.
The command unit works well. It "tested" the balance perfecly and gave me all three "Excellents". ( Same as DJI Ronin app).
My problem was when I tried to do a Panorama mode photos. Isometimes clicked the first frame, but not the others. I set the control for 20mm lens and 30% overlap.
It took a -89 degree, ( far left) photo, then a 0 ( center) photo and finally a 90 degree ( far right) photo.
BUT, the parameters display in the small screen said it would take 5 photos...not three.
When I tested the same setup using the Ronin app from my iPhone it worked every time perfectly.
I think everything else is working correctly. I only tried the timelapse mode briefly. It seemed to work, but I only did a few frames, not a long time.
Joe
