DJI Wanda
Hi Winterfell, thanks for reaching out. The max mAH shows the capacity of what the battery can run for on a full charge, and this number normally decreases as it ages. To possibly restore its capacity, (1) please charge your battery to 100% and leave it there for about 2 hours to cool down. (2) Then, let the battery drain by leaving it powered on or by inserting it to the aircraft with motors (without props installed) turned on until the unit reaches around 5%. (3) Let the battery remain turned off for about 2 hours. (4) Lastly, turn it back on and let it charge all the way to 100%.
Also, for battery maintenance which you may have probably seen in our guidelines, we recommend that you discharge the battery to between 40% to 65% and store it in a cool, dry space (at an ambient temperature of 22°C to 28°C) when it is going to be idle for more than ten days. Check the battery’s power every three months and fully charge and discharge it at least once. Please perform this routine maintenance to keep your battery healthy.
Hope this helps.
