Geebax
JJMik Posted at 12-7 20:15
I know how to avoid it but it has happened anyway. If the compass fails can you use The GPS MAP TO NAVIGATE? If you are in a mode. Can you still navigate using the gps screen/map?
The compass is not failing, a compass error means the aircraft has detected a compass anomaly, usually caused by switching the aircraft on while it is sitting on a magnetically 'dirty' surface, for example concrete containing rebar. The aircraft will then switch to ATTI mode, and ignore the GPS values. If that occurs, it cannot provide a GPS location to the Go 4 software, so will not be shown reliably on the map. And RTH will not work either. |
