DJI Go + Apple Ipad Pro 2018
4125 12 2018-12-9
FalconUAV
Hi there,
I've been trying to get my apple ipad pro 2018 to work with DJI Go 4 (latest) but its having none of it.
Unless the Controller + remote is within 2ft of the drone it gets a weak transmission signal.  I left the drone in the same spot, changed to my android tablet and it works absoloutley flawlessly.
Anyone every had this issue or reccomend a fix? Wish i'd stayed with android now!
Tried it in airplane mode, wifi turned off in the house, nothing.
Thanks in advance,
Lew
2018-12-9
DeepFriedOprah
Flight distance : 1709094 ft
Have you tried an Apple cable, not an aftermarket brand?
2018-12-9
rent
Flight distance : 1773458 ft
Russia
DeepFriedOprah Posted at 12-9 18:37
There is currently no Apple-branded cable that will make this connection with one end being USB-A (goes into the RC), the other end being USB-C (goes into iPad Pro 2018).
However, I think your suspicion about cabling is probably right.
OP: Would you try this with a double ended USB-A cable in conjunction with an Apple USB-C to USB Adapter? I'm interested in finding if this combination works.
Alex
2018-12-10
FalconUAV
Yes i've been struggling to find a cable for it as you say, they dont make one! its all USB-C to USB-C now.. will have a hunt for a genuine adaptor.
2018-12-12
FalconUAV
Looking on apple, the only cable they do it to a female USB which is no good, has to be male to go into the remote? God i remember now why i moved away from apple!
Anymore suggestions?
2018-12-12
fansa84fe8a4
Flight distance : 3 ft
https://www.amazon.co.uk/Belkin-Charging-Transfer-Chromebook-Smartphones/dp/B00WJSPCSG
Some Apple Stores also carry the Belkin usb-c to usb-c cable too.  https://www.apple.com/shop/product/HHSN2ZM/B/belkin-usb-c-to-usb-c-cable-usb-31
2018-12-12
FalconUAV
Thanks for the reply but those are both USB-C to USB-C, which wont fit in into the back of the inspire remote.
2018-12-12
rent
Russia
Maybe something like this: http://a.co/d/eUC0S3m ?
Or http://a.co/d/1Lu4XYY plus https://www.apple.com/shop/product/MJ1M2AM/A/usb-c-to-usb-adapter ?
Still waiting for my iPad to arrive, but will be interesting to see which combination works (if at all).
2018-12-13
FalconUAV
Ok, I've figured this out.
I couldn't change the image transmission channel in DJI GO, so changed my "region and language" to "united states"  on the Ipad itself and bingo, changed to channel 19 in DJI GO and works a treat - why oh why DJI are you restricting us brits on stuff like this?!
2018-12-15
Cyka_Delik
Flight distance : 5210 ft
How is there STILL no support for the new IPad Pros?
2019-4-10
Clevershot
DJI are aware of this issue and need to provide an update to app (DJI Go) and/or (Inspire 1 Pro) firmware to allow iPad Pro 2018 to work without image break up. Whether DJI will do this is unknown.
Our iPad Pro 2018s work seamlessly on our Mavic 2 Pros.
2019-4-18
Mounitinmn2
I have a follow up question. I am unable to get my iPad PRo 11" 2018 connected to my Phantom 4. The cable is charging the iPad, so I know it is connected, but DJIGo doesn't recognize it. Thoughts?
2019-7-2
Mounitinmn2
I have a follow up question. I am unable to get my iPad Pro 11" 2018 connected to my Phantom 4. The cable is charging the iPad, so I know it is connected, but DJIGo doesn't recognize it. Thoughts?
2019-7-2
