How does Quick Release Plate connect to a surface?
649 1 2018-12-9
richparry
Flight distance : 1620148 ft
I understand how the OSMO Pocket connects to the 2 prong "QUICK RELEASE PLATE", but I don't see how the plate connects to a surface like a helmet. Is it just a sticky tape on the underside of the plate that you press down on to affix the plate to the desired surface?
It would be nice if the plate accepts a 1/4 inch screw to make it compatible with industry standard tripods and plates.
thanks in advance,
2018-12-9
DJI Gamora
Hi richparry, thank you for bringing this query to us. Apologies for the confusion. The Quick-Release Base has an industrial adhesive strip for a firm hold to a helmet, board, and other surfaces. If you would want to use and put it on a tripod, attach Osmo Pocket to the Extension Rod, which has a 1/4 tripod mount to which you can attach a third-party tripod or base or Attach Osmo Pocket to the Accessory Mount, which is capable of connecting to a tripod. Kindly visit this link for more information about the new Osmo. Don't hesitate to reach us again if you have some concerns. Thank you.
2018-12-10
