Enable EXPO on yaw stick for the Spark
12Next >
13035 56 2018-12-10
Wolferl
Flight distance : 23793 ft
Austria
Hi folks,
Several people on the forum asked me to do a video about getting EXPO mode to work on the Spark.
So here it is!
BTW: The result shown at the end don't look great because of the frame rate conversion (30 to 25 fps).
Have fun,
Wolferl
2018-12-10
ssylca44
Flight distance : 434721 ft
Thank you for the info.
2018-12-10
FulanitoFlyer
Chile
I will definitely try this, Thanks for a clear and easy to follow video.
2018-12-10
DJI Natalia
Hi there, Wolderl. We appreciate your time sharing this information with us. If there is any help needed, please don't hesitate to reach us. Thank you.
2018-12-10
SAADHERO
Flight distance : 2269905 ft
Kuwait
Pretty Good to make better smoother footage
when needed
2018-12-10
A CW
Flight distance : 13877205 ft
Great info to share
2018-12-10
Warriewoodlad
Flight distance : 625230 ft
Another great instructional video. Thank you.
2018-12-10
Harleyrick
Flight distance : 29629 ft
This is great information. I was looking for a way to do a slower yaw. I am going to give it a try.
2018-12-10
AlexSW
This is great. Thank you for the great tutorial.
2018-12-11
Wolferl
Austria
@all:
Thank you very much for your support!
If you have more ideas to make the Spark perform better, let me know!
Cheers,
Wolferl
2018-12-11
ArnoSpark
Kenya
Indeed very helpful and well presented, thanks for sharing such essential information
2018-12-11
ZarcTheSpark
Flight distance : 460676 ft
I don't think this approach works with the latest version of DJI Assistant.
There is no main.js file to edit to enable debug mode, and get access to the exp functionality.
If there is another way, I would like to know it.
I think if you want access to the parameters enabled by debug mode (of DJI Assistant), then you may have to go back to some previous version.
2018-12-11
ZarcTheSpark
ZarcTheSpark Posted at 12-11 15:41
I see, he states that you need v1.1.2 of DJI Assistant 2, so yes, it only works with older versions.
2018-12-11
Junior SBC
Flight distance : 476483 ft
Brazil
Thank you very much for explanation. But, why to run DJI Assistant 2 in debug mode?
2018-12-11
Wolferl
Austria
Junior SBC Posted at 12-11 18:45
Thank you for the kind words.
If you start DJI Assistant 2 without enabling debug mode, you don't get "Basic Settings" in the menu on the left, and so you cannot do the necessary settings.
HTH,
Wolferl
2018-12-12
Ronnie.Choy
Flight distance : 1261211 ft
Singapore
Thank you Wolferl, that is a very useful video
2018-12-12
Wolferl
Austria
Ronnie.Choy Posted at 12-12 19:36
You're welcome!
If you have more ideas about making the Spark an even better toy, don't hesitate to tell me!
Cheers,
Wolferl
2018-12-13
tonepip
Flight distance : 167 ft
Hi, I am a bit of a Novice so. When I switch on my Spark and Rc unit so all is ready for Flying (Drone connected to RC unit) which unit do I connect to the PC? with the Cable? The RC or the Drone itself?
2019-1-5
Montfrooij
Flight distance : 2560453 ft
Very good information.
Can you also change camera settings like 25fps?
2019-1-5
nixuspix
Flight distance : 2864974 ft
Latvia
Great tutorial. Thank You
2019-1-5
Wolferl
Austria
Montfrooij Posted at 1-5 11:24
Hi Montfrooij,
I have specifically looked for a setting about this, but didn't find anything related.
Cheers,
Wolferl
2019-1-6
Montfrooij
Wolferl Posted at 1-6 02:11
Hi Montfrooij,
Ok.
That is too bad (for Spark owners).
Thanks for looking!
2019-1-6
S-e-ven
Flight distance : 5922034 ft
Thailand
That is a very usefull info. Thanks for the video!
2019-1-6
S-e-ven
Thailand
tonepip Posted at 1-5 10:02
I understood it this way:
PC via cable to Spark
RC via cable/wifi to Phone
RC and Spark connected
So like you wanna fly, just with a cable from PC to the Spark
2019-1-6
Wolferl
Austria
S-e-ven Posted at 1-6 05:30
Hi Seven,
Exactly that's the way how to do this. Thanks.
Cheers,
Wolferl
2019-1-7
tonepip
Thanks for the reply regarding Connection order.
I am trying to do the XPO Mod as per Wolfer but I cant get the Drone to be seen in DJI Go ASS V 1.1.2.
I installed Ass V 1.1.2 as per instructions on the Forum and all went OK. I am using Win 10.
Do I need to be Logged in to DJI via Ass V 1.1.2 first  to get Ass to see the Drone?
i have tried removing the SD card, as someone suggested but still can't see the Spark in Ass.
2019-1-7
Wolferl
Austria
tonepip Posted at 1-7 02:01
Have you installed the DJI USB drivers?
You can check if Sparky is seen in Windows device manager.
If your Spark is turned on and connected via a USB cable, you should an entry under "Ports" named "DJI USB Virtual COM"
HTH,
Wolferl
2019-1-7
tonepip
Hi Wolfer,
Yes all of the Drivers are installed. I have done the Initial Alteration to the ASS and at each Load up the other two alterations.
I do use the OTG cable successfully to  conect Drone to RC, Would this affect anything?
Will check out the Port Connection and let you know.
Once again, many thanks
2019-1-7
Wolferl
Austria
tonepip Posted at 1-7 02:46
Hi,
Eh, you connect the Spark and the R/C via an OTG cable? What????
You need to connect Sparky with a normal (non-OTG) cable to your computer. R/C and SParky turned on.
Cheers,
Wolferl
2019-1-7
tonepip
Hi Wolfer,
All has worked OK.
I did not do anything  different to what I was doing except I used my other Laptop, so may have a problem with my I5 Laptop.
Many Thanks for  your help etc
2019-1-8
Wolferl
Austria
tonepip Posted at 1-8 02:19
Hi Wolfer,
All has worked OK.
You're welcome! Great you got it to work!
Cheers,
Wolferl
2019-1-8
S-e-ven
Thailand
I tested the Expo a bit, today.
Since I have an extra Remote, I did set that one up for 0.1 in P, but also in Sport,  just only to 0.25
Unfortunately, it was very windy, today, so the results are not 100% meaningful, methinks.
And I still have to watch the SD-videos,  but in P there is really a smoother yaw possible.
However, also in sport it can be the option for full speed and still yawing without FPV effect!
Since I tried that before, without "hacking" the remote, and it did work sometimes well.
My guess is that setting sport also to 0.1 and flying in low wind conditions, that way can a smooth video pan be available for flying in sport mode.
Since I am using litchi, I know that the bird can fly quicker as 20kph (forward/backwards) or  30 kph (transverse) without inclining.
I will tweak the RC again, and then try to find low wind conditions.
Thanks for the  hint, Wolferl
2019-1-10
Tentoes
Flight distance : 6018255 ft
Thank you!
2019-1-10
Wolferl
Austria
S-e-ven Posted at 1-10 04:04
Hi Seven,
Thanks for the feedback! Please beware that these settings are stored on the Spark, not on the R/C.
Cheers,
Wolferl
2019-1-11
grin factor
Flight distance : 14580 ft
I’m new to the spark, so found this very interesting. Thank you.
2019-1-11
S-e-ven
Thailand
Wolferl Posted at 1-11 00:57
Hi Seven,
That what I had in mind and wanted to try out, but forgot the sec. RC.
(And didn't connect two RC's during the assistant 2 session to prove that)
And aside the basic testing, I was setting up litchi waypoints
So did not really get deep into it.
Thanks for the heads up!
But anyway, I will check on my theory for P/Sport.
I can always use  the sec. Spark, later,  to compare that!
2019-1-11
redman042
Flight distance : 54068 ft
This is very useful and, as a new Spark owner, I did not even know about DJI Assistant and the additional configuration features it allows until now. I have lots of fixed-wing RC experience and routinely use Expo on those, so it is very nice to know that I can do the same on the Spark. I will be enabling it right away (and need to explore what else DJI Assistant can do)!
Also, your video makes me wish that I owned a Spark in 2017 when I visited Austria with my family. That location you flew reminds me a lot of the countryside travelling from Salzburg to Halstatt. Austria is very beautiful.
2019-1-21
Wolferl
Austria
redman042 Posted at 1-21 14:50
Hi Redman,
You're welcome! I'm happy you enjoyed your visit to Austria. It is indeed a great country to live and people are quite relaxed.
If you find some interesting parameters, just let me know!
Cheers,
Wolferl
2019-1-22
Roy Rogers
Flight distance : 1186296 ft
Interesting , Thanks for the share
2019-2-3
StetsonWatkins
Flight distance : 1871611 ft
Thanks for sharing!
2019-2-3
12Next >
