Enable EXPO on yaw stick for the Spark
12
13038 56 2018-12-10
QQRUCH
Flight distance : 595518 ft
Hi Wolferl!
I followed your tutorial. It is very easy to follow. I changed the YAW parameter to 0.1 in P mode. But when returning when leaving "Control EXP" and moving the left joystick to the left and to the right, it continues to indicate a maximum of 10,000, however in its video it indicates a maximum value of 5270. Currently the firmware that I have in the spark and in the RC are the latest. Could it be that the change of the YAW parameter in the spark has not been recorded?
Aircraft Firmware: V 01.00.1000
Remote Controller Firmware: V 01.00.0600
Tomorrow I will try to prove it. Today is very windy. Thank's and best regards!  Good flights!!
2019-3-10
Wolferl
Flight distance : 23793 ft
Austria
QQRUCH Posted at 3-10 07:13
Hi Wolferl!
Hi,
Still having the maximum 10000 units is the whole point of using expo. The 5270 was just me not pushing the yaw stick all the way. If you want less yaw at the stick maximums, you can try reduce the maximums, too. You can also combine the two techniques.
HTH,
Wolferl
2019-3-11
QQRUCH
Wolferl Posted at 3-11 02:09
Hi,
Hello Wolferl!
Thanks for your quick response. This afternoon I tested the configuration and it works fine. Reacts slower to half the length of the stick. I will try to reduce the maximums also.
Thank you & Best Regards!
2019-3-11
PatriotArcher
Flight distance : 82169 ft
Where do you find V 1.2.2 of Assistant? I'd really like to try this but I can only find V1.2.4 which I have downloaded.
2019-3-11
PatriotArcher
tonepip Posted at 1-7 02:01
Thanks for the reply regarding Connection order.
I am trying to do the XPO Mod as per Wolfer but I cant get the Drone to be seen in DJI Go ASS V 1.1.2.
I installed Ass V 1.1.2 as per instructions on the Forum and all went OK. I am using Win 10.
Where did you find the V 1.1.2 of Assistant?
2019-3-11
Wolferl
Austria
PatriotArcher Posted at 3-11 13:39
Hi, have a look into the video description on Youtube, it's all there!
Cheers,
Wolferl
2019-3-13
Lysak2003
Flight distance : 500052 ft
Ukraine
Hello, Wolfgang! Just tried an Expo mode, and my result wasn't so smooth as I expected. Did you make some other examples of footages except that you show in the tutorial? There aren't any new video on your Youtube channel so maybe you downloaded it in the other source?
UPDATE: as I can assume, Tripod mode shows more smothness then EXPO. But maybe I am wrong and want to find out the point.
2019-3-13
Lysak2003
Ukraine
Just found the similar video with the same explanation. His footage at the end of the tutorial was supposed to be smooth. But it isn't (as for me).
2019-3-13
Wolferl
Austria
Lysak2003 Posted at 3-13 02:19
Hi,
Sorry, no other videos about yaw there. For video shot, I usually use one of my bigger guys :-)
Tripod mode is nice too, but it slows down roll and nick also.
You can enter tripod mode, then connect up Assistant 2 to see what yaw setting are now applied. You can now replicate them to the normal mode, or even improve them to your hearts content.
One problem remains: the Spark RC does not have high quality sticks though. Also the "dead area" in the stick middle cannot be reduced (at least I don't know how, if anybody knows, please reply).
Lets face it: as nice as the Spark is as a product, it's still a beginner level bird.
Cheers,
Wolferl
2019-3-13
Lysak2003
Ukraine
Wolferl Posted at 3-13 07:51
Hi,
Thanks for the swift answer. Absolutely agree with you! Will continue to practice with tripod mode.
2019-3-13
PatriotArcher
I wonder if there's any way to unlock the gimbal in sport mode with this method. If anyone can figure it out or knows another way to do it that would be great!
2019-3-13
PatriotArcher
Wolferl Posted at 3-13 00:46
Cheers,
Thanks! I tried it and it really helped.
If I change any of the max angles would that change it's top speed?
2019-3-14
Wolferl
Austria
PatriotArcher Posted at 3-14 06:54
Glad it helped.
These settings will not affect maximum horizontal speed. But there are other settings which define the max speed for the various modes.
Look at this video from ca. 5:36
There are other videos which show that also.
Cheers,
Wolferl
2019-3-14
Walleye
Wolferl Posted at 3-14 12:57
Glad it helped.
Hello Wolfer,
Thank you for the informative videos.  For a newbie and not very computer saavy it was very helpful.  I finally (I think) was able to modify the settings.  As soon as it warms up and the winds die down I'll give them a try.Walter
2019-3-28
Rustic17
Flight distance : 2733760 ft
Nice video!
2019-3-28
Wolferl
Austria
Thanks for the appreciation!
Cheers,
Wolferl
2019-3-29
fansd59551e2
Flight distance : 2340295 ft
Greece
Thank you!
2019-8-8
12
