New Osmo Pocket Firmware Released(2018/12/11)
123Next >
28730 100 2018-12-11
fans3ff87f5e
Had the problem of failed update. Formatting the memory card fixed it for me.
2018-12-15
jaybroho
Flight distance : 24583 ft
fans3ff87f5e Posted at 12-15 00:02
Did you use the app to format? Or the computer?
2018-12-15
jaybroho
so my first attempt at this post failed because of my images.  let's try this again.
I finally got my device to update to the latest firmware after it always stalling at 52%.  What i did was risky and you could end up bricking your device so I definitely don't recommend doing this.
Anwyays, what i think happens during the firmware update is the first 50% of the update it transfers the firmware over to the device.  after it reaches 50% the device then runs the update.  So what I did was after it hit 50% maybe 51% i pulled the device from my iPhone X. (GASP)
DO NOT TURN OFF THE DEVICE.
I was a little worried that i could brick it but what ended up happening was the device showed an update screen a few seconds after disconnecting it.
When it got to 100%, I checked my device info (noticed that there was no typo anymore) and this time...
I hope this helps anyone.  I'm just glad I don't have to return it.
2018-12-15
5tua12t
5tua12t Posted at 12-13 12:53
+1 to what Manro said, no sign of D-Cinelike ? Was this pulled from public release?
D-Cinelike Coming in a future update!
2018-12-15
djiuser_p4mVfmGpYPdR
Flight distance : 183796 ft
Successful update but the record button doesn't work on the osmo pocket...how do I fix that? I just got it today but haven't been able to even use it...it automatically updated firmware but the only way I can take pictures or videos is with my phone connected. Please Help DJI!!!
2018-12-15
djiuser_Xm27g7mYla05
I encountered error during the firmware upgrade.  It prompted me with the following error after 52%.
Are there any solution for me?
2018-12-16
Michael Miami Sweden
Flight distance : 24199 ft
Where did story mode go? I can't seem to enter story mode as in the instructions video. Its simply isn't there anymore. Please advice.
2018-12-16
fmhobby
Austria
hi,
gibt es für Osmo Pocket auch deutsche Menüsprache?
Danke
2018-12-16
djiuser_m7aM2AwgQaSy
Indonesia
Kellaros Posted at 12-14 00:32
Could not update to the new firmware, install stopped at 53%
Phone model: Samsung Galaxy S9+, Android 8.0
Ensure ur micro sd card abailable min 20 %
2018-12-16
jaybroho
djiuser_Xm27g7mYla05 Posted at 12-16 07:18
I had the issue and posted my solution above.
2018-12-16
djiuser_0HGlsvoofiPr
Mansi95 Posted at 12-13 03:00
my osmo stopped working after a few hours of use and it no longer lights up
It also does not load.[Image]
Same issue here.
2018-12-16
edenshii
Philippines
I am also having the firmware update error same as a few of you here have. I hope I can get an answer.
I tried to uninstall then reinstalled the app. I have also bought a new micro SD and formatted it.
I have contacted the DJI Support youtube channel but never heard from them. (although they replied to my comment and asked for a screenshot of the error. I already provided them with it but still no answer)
This is my first time buying a DJI product. I hope there is someone who can help me.
Thanks.
2018-12-17
scotsmandc
Will the pocket eventually get hyperlapse?
2018-12-17
wormz30
Flight distance : 226460 ft
Come on DJI. WTH? Can't even get this firmware to update. Stuck at 52% like others. Are we going to have another Phantom 4 firmware debacle all over again?! I just tried some of the solutions for some other users and those haven't worked for me.
2018-12-17
wormz30
jaybroho Posted at 12-15 13:41
Ok so I can confirm that this technique works somehow....
I tried this a few times and what i did was wait till 50% when the process really slows down, then I unplugged the device from the phone (without turning anything off) and then kept it unplugged until the phone gave me the notification that the device isn't plugged in, then I plugged it back in and then it proceeded to do the update.
Hope this helps?
2018-12-17
thbronner
My Osmo Pocket doesn‘t connect to the App any more.
The activation and the Update went well, but now it doesnt connect. Tested with three different iOS-Devices
2018-12-17
Satureyes
Flight distance : 524908 ft
thbronner Posted at 12-17 11:09
Turn on flight mode on the iOS device then try and reconnect.
Known issue causing disconnects.
2018-12-17
edenshii
Philippines
I chat with DJI Chat support agent and my firmware update problem was forwarded to the Engineering department. Is it really hard to update firmware with DJI Osmo pocket? I have tried the suggestions posted here so far  it didn't solve the problem. But I will keep trying.
2018-12-17
edenshii
Philippines
Thanks jaybroho and wormz30. After hours of trying your procedure, I have finally updated my firmware. Thanks a lot.
2018-12-17
thbronner
Satureyes Posted at 12-17 15:12
Tank you for your reply!
I‘ve tested it in flight mode. Unfortunatelly Osmo Pocket doesn‘t connect. I even don‘t hear the „connecting-sound“ of the iPhone when I connect the devices.
2018-12-17
IamWedge
Flight distance : 321398 ft
Seems to work pretty good. I didn't have any issues updating. I did update through the Mimo App.
2018-12-17
Nick Hayman
Why is there no PAL framerates in this product?
It makes it useless in all PAL countries, especially for users who want to cut it with other cameras.
Please add that to the next update.
2018-12-18
Nick Hayman
2018-12-18
Satureyes
Nick Hayman Posted at 12-18 00:59
Doesn't your edit timeline take multiple frame rate sources?
I shoot at 4k 30p on the Osmo and pull it into a 24p timeline. I don't see any issues?
2018-12-18
Satureyes
2018-12-18
mareklew
Flight distance : 4026 ft
Second that! What camera product ignores frame rates like that? Especially that there's no way to select 25fps on device
2018-12-18
mareklew
Satureyes Posted at 12-18 01:22
1. I literally DO see a problem in how the video looks like afterwards and how much processing power does it require to look halfway OK
2. 24p is 23.976 in NTSC and its a 4/5th of 30fps, which is actually 29.97fps. Getting from one to the other is possible with telecine pulldown or in other words, mix-matching integer number of frames.
PAL 25fps is 25.000fps, which is not a rational fraction of 29.97fps
2018-12-18
Cedman
updated and working fine using 128gb card
2018-12-18
Satureyes
mareklew Posted at 12-18 06:05
Looking in the Mimo app - they list the PAL and NTSC frame rates - but obviously they dont offer an option - they bundle them together so they have 30fps listed and then 29.97 in brackets.
Whilst this is a PITA for more pro users it's not going to be any issue for the main intended audience of this product.
Personally I throw it onto a 24p timeline and it seems to be ok with mixed sources. If I was editing only the OP footage I'd work in the native timecode anyway and then export it as whatever I wanted.
I'm not sure the PAL/NTSC issue is as big a problem as it used to be.
2018-12-19
mareklew
Satureyes Posted at 12-19 06:01
Funny, how the ones, who don's see a problem with missing PAL option on the device are the ones, who are working in NTSC.
24fps video is NTSC framerate, see my point #2 above. I'm working with 25fps.
2018-12-19
thbronner
Still no connection to the App.
Still Problems with accessing to the videos taken by Osmo Pocket
Still no reaction from the Support
2018-12-19
Satureyes
mareklew Posted at 12-19 10:13
I'm working with 24p and I'm in the Uk.
I don't understand why FCPX set to a 24p timeline can't deal properly with the 29.97 footage. Ok - it's not ideal but what's the difference with shooting at that or editing at that if the timeline can handle it?
What am I missing?
2018-12-19
fans1aec149b
Just updated my osmo firmware where’s the 1080p 120fps?
2018-12-19
mareklew
Satureyes Posted at 12-19 13:58
You are missing, or ignoring that:
1) it's your choice to work at 24p and this post is about people, like me, working at 25p, because they work, like me, on PAL standard.
2) your opinion that "not ideal but works" is not shared by all, especially for me "not ideal" is more like "looks crap and I can't accept it in my output".
2018-12-20
okcthunder
Flight distance : 102208 ft
i just purchased my new osmo pocket and updated the firmware as well. For some reason i do not see or access the "Story" mode. Does anyone else have this issue? can it be resolved? thank you
2018-12-20
travellingcats
India
Nice firmware update! Really a great one.
Thanks team and keep up such an ultimate work!
Also check - ugc net
2018-12-20
Satureyes
okcthunder Posted at 12-20 07:19
It’s not in the app. Was removed before release. Only beta testers have Story mode - also same as colour profiles. Those are due in a future release. As to when... well.. welcome to DJI!
2018-12-20
okcthunder
Satureyes Posted at 12-20 10:44
thank you for your reply Satureyes! Man i was hoping to use it!!! oh well, guess we all will have to wait lol
2018-12-20
djiuser_K2OXdpL1ecia
Help
Firmware update fail at 53% everytime.
the SD card is new and works ok to record videos with the osmo pocket. And I can format the card. It has 59Gb free space.
after failed update, in the SD card there is a hidden folder /MISC/LOG with a txt log with some information:
[00184737]Firmware upgrading[1]...
[00188766][01 00] Firmware upgrade start...
[00188772][01 00] Firmware upgrade tracecode 0x00010000
[00188781][01 00] Firmware upgrade tracecode 0x00020000
[00202870][01 00] Firmware upgrade tracecode 0x00030000
[00202877][01 00] Firmware upgrade tracecode 0x00040000
[00222765][01 00] Firmware upgrade tracecode 0x0f040502
[00222772][01 00] Firmware upgrade tracecode 0x00020000
[00236840][01 00] Firmware upgrade tracecode 0x00030000
[00236847][01 00] Firmware upgrade tracecode 0x00040000
[00256748][01 00] Firmware upgrade tracecode 0x0f040502
[00256755][01 00] Firmware upgrade tracecode 0x00020000
[00270851][01 00] Firmware upgrade tracecode 0x00030000
[00270857][01 00] Firmware upgrade tracecode 0x00040000
[00290787][01 00] Firmware upgrade tracecode 0x0f040502
[00290793][01 00] Firmware upgrade failed at crc check! [00290800][01 00] Firmware upgrade finish failed (step = 2, err = 0xf2).
[00293808][01 00] Firmware upgrade finished failed.
[00293814][01 00] Camera firmware check error, error count increase.
[00293820]Packet upgrade failed at firmware upgrade, Ret = -1.
2018-12-20
djiuser_g0IEwCvCk8YL
Dominican Republic
Why does not osmo pocket have a story mode?
2018-12-23
123Next >
