New Osmo Pocket Firmware Released(2018/12/11)
123
28766 100 2018-12-11
BenScharp
I hope that a full lock mote will be added to the next update.
2018-12-23
edeone
Flight distance : 164685 ft
fmhobby Posted at 12-16 12:29
hi,
gibt es für Osmo Pocket auch deutsche Menüsprache?
Danke
ja, in den einstellungen
2018-12-23
djiuser_kCSpG5XQyEBP
After the update My camera has defaulted to Japanese and I cannot figure out these button sequence to get it back to English.  Please help.
2018-12-24
2018-12-24
mareklew
Flight distance : 4026 ft
djiuser_kCSpG5XQyEBP Posted at 12-24 13:58
swipe down
tap gear
swipe left
tap bottom-right (four tiles)
tap top field
select English
enjoy
2018-12-27
edenshii
Philippines
jaybroho Posted at 12-15 13:41
so my first attempt at this post failed because of my images.  let's try this again.
I finally got my device to update to the latest firmware after it always stalling at 52%.  What i did was risky and you could end up bricking your device so I definitely don't recommend doing this.
Hi jaybroho. Thanks a lot for helping me.
Thanks for the patience in replying to my PMs.
I have asked my sister to upload the video in my nephew's channel (since I am camera shy). To everyone who wants to know how I was able to update the firmware (through jaybroho's help), [/url] to the simple video. Thanks.
2018-12-27
hedac
I couldn't update past the 53%.. but I was finally able to update the firmware successfully but using a HUAWEI P20 instead of my Oneplus 6. Very strange. I was going to send the unit back but decided to give it a try with another phone(not my phone) And it worked! Now I don't know if there is an issue in the Osmo Pocket or not, because Tech Support by email told me that I would have to send back the Osmo Pocket. But it works great now.
2018-12-28
LeTraKeuR
Flight distance : 113058 ft
Cool it’s great thing
2019-1-1
LionelB
Fillit Posted at 2018-12-13 22:06
Hi when i connect to my android phone i dont get a warning "new firmware is available" .  Its running on original version. The device and phone properly connected because "photo mode"and others is working
I’ve got the same problem, did you have any subsequent success and if so how ? Thanks
2019-1-2
LionelB
Fillit Posted at 2018-12-13 22:08
When i connect the phone and device i dont get the warning "new firmware is available" .  I can use mimo for photo makng  but cannot upgrade.
Yep same thing here, did you ever get this resolved ? I’m still running Ver 1.02 and seem to be stuck with it although having read all the problems some people are having post upgrade may be it’s not a bad thing.
2019-1-2
Richard Guzman Tolentino
Philippines
I just want to know why on my battery info says 500Mah it sould be 875Mah
2019-1-3
aacurt
App will not allow me to register. Captcha just keeps resetting
2019-1-9
fansc2d292a4
Okay, after numerous attempts to update my fw, trying different SD cards, reformatting, resetting the device, uninstalling/reinstalling app, trying on both iOS and Android, all with no luck, including trying the previously mentioned "unplugging the Pocket when the the update hits 50%".
I noticed my Pocket getting kinda warm, so I decided to do something that I've done before with another unrelated device that I needed to do a fw update on. I switched off my Pocket and put it in the fridge for 20 minutes .. yes, in the fridge!! I took it out, switched it on, reset (again), inserted and formatted the card (again), then connected to my phone and went through the update process, this time without a hitch! There's still a slow down at 50% but it then jumped to 69% and gradually moved up to 100% within about 3 minutes.
Now, this is what I did and I cannot guarantee that it'll work for anyone else! I wish you all the best of luck..
2019-1-11
djiuser_QitqeqUT7Vk6
When is Android app getting log recording functions. It's on the Apple version?
2019-1-18
PedroHalito
5tua12t Posted at 2018-12-13 12:53
+1 to what Manro said, no sign of D-Cinelike ? Was this pulled from public release?
They put it only in Apple app!!!!
2019-1-18
fans862a76a7
fans81ec2788 Posted at 2018-12-14 18:36
Same here did all the same steps you did, still get the "Update Failed" message while trying to install it.
Also get a Format Failed message when trying to format the SD card, even though it shows it is installed with 201gb available.
I had all sorts of problems with a slow memory card from upgrading to recording. Once I purchased Sandisk 128gb extreme plus card all these problems went away. I believe all these issues were happing because of slow read write speeds on memory cards.
2019-1-21
djiuser_zWKT8wl5vbSv
Norway
This product is a joke, here's why:
1. It fails to ask/let you upgrade firmware if you miss the first request to do so, meanwhiie it asks you to download the MiMO app in a nagging instructional video from inside the MiMO app every single time you start MiMO, Inception anyone?
2. All its limitations are plain software - so called software crippling of a capable device. It's marketed as tiny as thats the whole purpose, not having to use something big like a gimble or a phone, yet it forces you to use a phone if you want to change iso, shutter and fps to 24p, simple functions the device would be fully capable of changing on the eevice itself without a phone if put into the device menus, it's a 50 line command-set that takes one day to build a menu for.
3. Same with facetracking / activetrack, the device's internal processing is fully capable of doing tracking at 4K, stop limiting this device artificially or hire developers that actually develop and does the work this device deserves.
2019-1-26
fans66c53b5c
Moldova
Hello i hawe a question, i can find the D Log profile in me Dji osmo pocket, can you help me?
2019-1-27
edenshii
Philippines
For unknown reason, I had a problem updating the DJI Osmo pocket and so we documented our process and created a video. This is risky so anyone who wants to try, may do so in their own risk. But hopefully, DJI will solve this problem in behalf of all others who always encounter a problem when updating the firmware.
Here is the video:
2019-1-28
user35943af125
Mexico
Amigo no puedo actualizar el osmo pocket me manda error 0x00140002 ayuda
2019-2-3
edenshii
Philippines
djiuser_g0IEwCvCk8YL Posted at 2018-12-23 19:02
Why does not osmo pocket have a story mode?
HI,
Were you able to find/use story mode now?
2019-2-18
123
