Satureyes
Flight distance : 524908 ft
Cameleon Posted at 12-13 08:08
No idea I'm afraid, I don't use it. I only know about it as I've been looking into the iPad pro to use as a video editor myself, but I haven't actually used it.
DJI appear to confirm above. Looks like you'll need LumaFusion with some other way to access the files. I think LF supports the SD card readers, so you'd need a USB-C card reader and copy it to the iPad that way? It *might* even detect the OP itself connected via USB-C direct, but I really dont know.
I have lumafusion. Also the SD reader and also WD MyPassport Wireless Pro.
If I put the files from the OP to the WD drive I can import to Luma. However Luma plays the files fine- but with a warning they are not compatible with iOS.
Plugging the card directly to the iPad only allows the files to be seen in the photos app- and then we can’t import the 4k60 files anyway.
Limafusion does not allow browsing to the SD card directly. Only via third party access to cloud services and also the WD drive.
On the WD drive there is a SD card reader and a USB 2.0 socket. If the OP is connected via USB then Lumafusion sees the card (because it’s via the WD drive)
For now it seems the simplest solution is 4k30 which obviously is a shame and not making the most from the Osmo.
What I don’t understand is that some people have used Luma to import GH5 movies at 4k60 via the photos app method.
