I was able to activate the OP with my iPad 4 mini without any problems. Also, the firmware update works flawless AND I was able to keep the OP connected to the iPad in order to shoot pictures and videos. To make it work, 1. Download the app, (no need to open it, it will open by itself after connected to the OP) 2. make sure you turn on the OP before you connect it to the iPad so it has time to initialize. 3. Follow the activation procedure screen. 4. Before updating the firmware, make sure you have your mini sd card inserted. 5. be carful, watch the gimbal not touching the edges of the iPad. As long as you don't switch to selfie mode you should be fine. I hope, this helps Good luck and happy shooting
