Super Fine mode - lower bitrate
733 3 2018-12-13
TheFlyingDutchmanInNorway
Flight distance : 717336 ft
Norway
Hi.
I did a quick test with Normal vs Super Fine mode.
I use Firmware 1.02.00.20
When I shoot 4K 25P in normal mode, the bitrate is approx. 85-105 Mb/s
When I shoot 4K 25P in Super Fine mode the bitrate is approx. 65-80 Mb/s.
I would expect the opposite.
Now it seems that Super Fine mode has lower bitrate.
However, the Super Fine mode has less noise than Normal mode. I dont know if there is a Noise reduction applied?
If Super Fine means Noise reduction I can understand that the variable bitrate used gets lower because of cleaner footage.
But the DJI FAQ explains that Super Fine uses higher bit rates thus giving better quality. But that does not seem to be tha case.
Any comments, anyone?
regards
Terje
2018-12-13
Scott.
Flight distance : 294006 ft
Curious to know how you got 25fps?
2018-12-14
fansd8cc4f88
Flight distance : 166289 ft
Scott. Posted at 12-14 09:51
Set it to pro mode and there will be 24, 25 and 50 modes
2018-12-14
fansd8cc4f88
Btw in 1080p the superfine mode is 25mbit while the normal mode is 35mbit. Very strange, should be the other way around...
2018-12-14
