Failed RC update I1...Now RC says it's a phantom 3 RC
1252 5 2018-12-14
patou72
Flight distance : 3316614 ft
Switzerland
Hello Folks,
After a long period without updating my Inspire 1 and RC i thought it's time to get it done once more.
Bad Idea!!!!
I connected my RC with my Ipad and uploated the new firmware and proceeded the update. After maybe 15 minutes the yellow updating wheel indicated always 0% so i decided to interrupt the update. I needed to shut off the RC because everything was stuck on the ipad.
You can imagine what followed:
RC LED has a greenish light and when i connect the ipad the DJI Go App indicates that the RC is now a RC for a Phantom 3.
-I tried a few times the reset for RC    (Hold C1 + C2 + Shutter Button and turn off with Power Button --> then the same sequence when turning on power) but nothing happens!!!
- Tried also to reboot the RC with different USB sticks and the special *gs_ofdm.bin* file without success.
Does anybody out there has another idea what i can do?
Thanks for all your help!
Patrick
2018-12-14
Caspers driver
Flight distance : 4540515 ft
Bummer big time dude !
Have you tried to switch (choose) the inspire manually on app without anything connected?
I had the same thing happen to me 2~3 weeks ago right out of the blue. I had to shut down and try several times, but it seems that is what I did to get it to not think it was a P3S.
Hopefully someone will have the magic bullet if this isn’t it.
BTW: I hadn’t just updated when I had my problem. Just random luck.
2018-12-14
patou72
Switzerland
Caspers driver Posted at 12-14 16:34
Hello Caspers driver,
Thanks and yes i tried to switch to inspire manually but it didn't work. The only thing i saw then when i get in the menu holding the three bars in the upper right corner was:
- No upgrade available. And also no option to downgrade too.
after a lot of search in google i didn't find any plausible explanation or solution.
Thanks for your help
Patrick
2018-12-15
patou72
Switzerland
Would be great to hear something from the DJI Admins and specialists
2018-12-15
Caspers driver
patou72 Posted at 12-15 12:46
Sorry I couldn’t be more helpful Patrick.
I’m also surprised someone from dji hasn’t jumped in. Hopefully Very soon.
Good luck. I feel your frustrations.
2018-12-16
fansc4294f8a
Flight distance : 800876 ft
Austria
Same Problem with my new bought Inspire 1 RC, second Hand :-(
First of all no USB connection via Handy was available, so I came along and read many problems about the usb pcb board, such as bad soldered usb ports on the board. so I managed myself to fix it, but nothing changed. Today I tried to change the two HDMI Modules which are stuck on the usb board -> and then for the first time it worked, i got a connection through dji go app. that there is no connection but it was recognized in the app. but with firmware "version unknown"
After that i go back to dji go app - main menu where the model can be chosen. when i plug in the usb cable into my phone, it is showing me "Phantom 3 Professional" :-(
Also by long press on this menue the 3 bars, it comes into an menu where following information is presented: GL300 RC, Verion Unknown and i can't chose another firmware.
Also tried after that to use gs_ofdm.bin, but also no help. also tried resetting the remote without any changes.
So i hope DJI move UP HERE and try to help.
2019-8-24
