RYZE
Super Moderator
Effess Posted at 1-11 10:48
After updating to 01.04.78.01 firmwareTello has become "a completely different bird, unstable fight, controller response variable, sometimes just moving up and down a foot or so when hovering." I also noticed if you were about a couple of metres up it would CLIMB upwards when you were going forward, and DESCEND by itself when below a meter and going forward. Also, tap to land is now hit and miss - sometimes it just bounced along the floor and did a sort of hop up again! I did a reset, re calibrated the IMU and did the center of gravity thing - But NO... no.. no stable flight!!! Its just as iffy! I am so disappointed Ryze ... a perfect little drone to an uncontrollable monster with an update! Another thing... if you remove the Prop guards, it flies better - no rise-fall thing.. at least not in my limited testing. C'mon Ryze fix this, PLEASE!!!!
We are very sorry about it Effess. I am going to take care of this for you right now. At first, please check if the following info would assist.
- Kindly check if one or more prop guards has been broken or not.
- Make sure that the altitude does not exceed 1000m
- Kindly refer the image below to check if the flying environment is good for hovering and flying.
If persists, for info collecting and further assistance, would you contact the right support at support@ryzerobotics.com? Thanks a lot in advance. |
