Waterproof case for osmo pocket
123Next >
71120 117 2018-12-17
RikDingo
Flight distance : 2358225 ft
The waterproof case is is shown on the osmo pocket page. But we can not buy it on the store. WWhen will it be available ?
I'm waiting for this part to buy the osmo pocket, so hurry up dji !
2018-12-17
DJI Stephen
Hello and good day RikDingo. Thank you for the inquiry and for the interest with the waterproof case for your DJI Osmo Pocket. As of the moment we still have no information when will the this accessory be available. For the latest news and updates for the DJI Osmo Pocket and its accessories please visit out official website at www.dji.com for further details. Thank you for your support.
2018-12-18
Biggruffbear
Like RikDingo, I'm waiting for the waterproof housing. I'm going to Australia at the beginning of February, and will be diving the Reef. If the housing isn't available by the time I go, I won't be buying the Osmo. Full stop - too late. I'll do any above ground gimbal shots with my (brilliant) Mavic Air.
2018-12-30
fans7712ee05
Flight distance : 138376 ft
Mexico
You can not make a flat dome. There will be distortion under water. Need to make a sphere !!!
2019-1-8
Lyagukh
Flight distance : 68179 ft
Ukraine
fans7712ee05 Posted at 1-8 17:44
I own lots of underwater housings: Olympus 8080, Olympus u720, Hammerhead for Sony handycams, Meikon for Sony RX100, GoPro 3 Black. All of them have flat viewports, none of them gave distortion. What have I done wrong? ;)
2019-1-8
Let4ik
Mexico
If the distance from the front lens to the dome a few millimeters, then there is no problem. When the distance is longer, distortions begin. The image with a flat dome will be 33% narrower than the real one. The spherical dome refracts light without distortion.
2019-1-8
mimimomo
New Zealand
If your only use-case is underwater, then you are better off with the GoPro 7 - the gimbal will basically be locked in that DJI housing.. Underwater shots are pretty damped and smooth anyway, so no real benefit to a gimbal in that environ.
2019-1-8
Lyagukh
Ukraine
Let4ik Posted at 1-8 19:32
It depends not as much on the distance you mentioned but on the lens focal distance. Consider all three kinds of distortions:
- refraction will in effect increase the focal length by approximately 25% - you see the same effect through your mask (and in a typical mask there is more than a few millimeters between your eye and the glass).
- radial distortion (pincusion) will be present with flat port and less so with spherical (or rather hemisperical) dome. It's effect is really noticeable for wide lenses unless we are talking about professional use for which OP is not suitable anyway. Also it can be corrected to some extent in post with one of several plugins for Photoshop
- chromatic aberration - roughly the same logic as for radial distortion
On the other hand hemispherical domes introduce problems with focusing. The port itself works like an additional lens element (and that only underwater) which creates it's own "virtual image". And you should focus on that virtual image, not the real thing. That's one reason why original underwater housing for GoPro Hero had poor underwater performance because GoPro has fixed focus and those housings had dome ports. Many divers including yours truly were forced to replace the dome with flat one. Even if your camera allows focusing, image in the corners may still be out of  focus with dome ports meaning you want to increase DOF by stopping down your lens - and underwater there is never too much light
All in all, unless you want to shoot with really wide lens, flat dome is IMHO acceptable for amateur underwater use.
2019-1-9
Let4ik
mimimomo Posted at 1-8 20:01
in underwater photography the problem of stabilization is one of the main ones. It is not clear how well Osmo will work in low light conditions under water. Rhe light under the water is always not enough. Need to try with and without underwater lights
2019-1-9
RSW
Flight distance : 116736 ft
Lyagukh Posted at 1-9 02:27
There is one specific difference. Because of the gimbal movement within the housing, the camera angle will be constantly changing in relation to that flat port. You will certainly see the distortion as the gimbal moves. Walk up close to and aquarium. As long as you are looking straight ahead, distortion is minimized. Turn you head side to side and the distortion becomes evident.
2019-1-9
Let4ik
Mexico
That's right. The radius of the sphere should be calculated so that the focus is at the correct point. I am sure that the flat dome will not work correctly with the gimbal
2019-1-9
Lyagukh
Ukraine
RSW Posted at 1-9 14:58
If you look at the housing DJI is advertising, it is apparent that it is not intended for large angular movement of the gimbal. Imagine you are going to do the selfie - which part of the housing will get into the view? Right, it will be the black rim You may call it a deficiency and I will not argue.  But it is what it is. And for small angular movements flat viewport will not introduce that huge a distortion.
2019-1-10
Lyagukh
Ukraine
Let4ik Posted at 1-9 16:41
We have to wait and see. If the housing will be available by summer, I will definitely buy it and give it a go.
2019-1-10
Let4ik
Luxembourg
Lyagukh Posted at 1-10 00:59
I think that third-party manufacturers will make the housing before the summer
2019-1-10
Lyagukh
Ukraine
Let4ik Posted at 1-10 15:30
Who knows? I would imagine lots of AliExpress sellers will then pretend they have it, then they will fail to ship, people will be  frustrated, etc, etc Consider current situation with PGY phone holder for OP
Also I'm not sure I would trust small garage-like manufacturer ability to produce underwater equipment. While everyone who takes their equipment underwater should be prepared to loose it, probabilities are different
2019-1-11
Giammi
Flight distance : 847795 ft
That's why I kept my GoPro Hero 6 Black with Telesin dome along with the Osmo Pocket.. they're complementary products, not substitutes..
2019-1-11
Lyagukh
Ukraine
Giammi Posted at 1-11 08:01
And then it comes to grading, flat/log profiles and D-cinelike
2019-1-11
Giammi
Lyagukh Posted at 1-11 09:15
Yes, you're rigth.. but I keep my GoPro only for underwater clips where you do not have to be too much consistent with the rest of the film.. colors are anyway too different..
Different case is to proper color match clips coming from the OP with those from my Mavic 2 Pro.. in that case yes, I definitely need D-Log or D-Cinematic at least
2019-1-11
Lyagukh
Ukraine
Giammi Posted at 1-11 09:19
Even underwater it strongly depends on lighting conditions. And it is not always trivial to quickly understand where the sun is at the moment. And if you use some kind of artifical lighting - it becomes even more involved. One of the first lessons I learned some 15 years ago - shooting underwater at night is easier
2019-1-11
Let4ik
What have Gopro? There are hundreds of underwater cameras. Using the gimbal under the water is an evolutionary idea and it is very interesting to try to implement it. After we compare the results and the answer will become obvious whether it is necessary or not.
2019-1-13
Giammi
Lyagukh Posted at 1-11 14:59
Yes, you're right. But I'm not an underwater photographer and I have no heavy equipment. Just taking some clips while scuba diving for fun.
2019-1-13
Lyagukh
Ukraine
Giammi Posted at 1-13 23:27
Same for me. But the more you dive the better pictures/video you want Especially if you primarily dive in one and the same location where every moray eel is your personal friend
2019-1-14
fansae6f449d
Clear and helpful explanation!
2019-1-24
El Diablo
2019-1-25
A CW
Flight distance : 13838848 ft
Looks like a cool little gadget
2019-1-25
Talisa
Bringing back the original question:
Any update on availability of the DJI case?
in Europe?
I'm going for diving on Zanzibar end February. Would be great to have the case im my hands than. (Otherwise i need to carry my hugh case for my Panasonic with me)
Thx
Talisa
2019-1-25
OMSO_KRAPS
Talisa Posted at 1-25 02:03
in Europe?
Hi Talisa,
This is my very first post Joined the forum as well for some OSMO pocket tips and updates. I chatted with customer service. Still the same response from the very first post that actually answered the question. "no further information available please go to website". I too bought the pocket thinking to get some underwater shots with the case, this was for early Jan. That trip has passed but man I loved the pocket still got some great shots. Any who its just the waiting game now.
2019-2-1
Geopixlz
So the OP got released at the end of November and it’s now February... I sold my black 7 to buy the OP and was going to purchase the underwater case which ultimately would give me a much better footage in shallow depths BUT where is the elusive case ?? Surely if they had it on demo at the launch of the Osmo pocket then why is it not ready for mass production ?? Was it just a not functional prototype ? Are they having heat issues ? To me this is typical DJI... promises and bent truth :/ I’m leaving to go full time travelling in a month time and I need an underwater case ! Had I known the case wasn’t going to be sold anytime soon I would have not purchased the OP and would have kept the GoPro black 7 !! not happy DJI... NOT HAPPY
2019-2-5
djiuser_ZnSgIVoCzqFr
Japan
Geopixlz Posted at 2-5 04:15
I’m the same. I’ve been wating for the waterproof case since OP came out. I will be gone for long vacation the end of next month. I guess dji has a problem with the port. The port should be bigger to cover the move of its lens. I hope they will start selling asap. Please dji!!! You guys make awsome stuffs. Don’t make me disapointed.
2019-2-5
StardustGeass
Been waiting to get an underwater case because on march I'll be going to snorkel.
I hope I don't regret buying this device because of the long wait of promised accessories.
Tbh, waiting as well for the charging case and the stick, but those two can wait.
2019-2-5
Geopixlz
DJI ADMINS ?? Any idea when the case is going to be released ? March ? July ? November ? 2020 ? Please give us at least a time frame !
2019-2-5
Brainbustah
What's the point of having an action camera without a proper waterproof housing?
2019-2-6
El Diabolico
Welcome to the waiting impatiently list bud...
2019-2-7
El Diabolico
djiuser_ZnSgIVoCzqFr Posted at 2-5 06:00
Please don't make assumptions when you have no proof. There are a couple of demos outhere (in an Expo and just some random guy ) that they show the gimbal underwater and how to insert it on the case and there's no issue whatsoever with clearance.
Companies rarely have availbale all accessories on launch. It happens all the time in the Photography industry for many reasons. Don't forget that we are still in winter, as do the majority of the countries where DJI has the higher sales volumes.
2019-2-7
hallmark007
Flight distance : 9827923 ft
Brainbustah Posted at 2-6 23:56
You do have a waterproof for an action camera, it’s called go pro, lol
2019-2-7
Japan
hallmark007 Posted at 2-7 01:59
Hi DJI! You don’t have to wait until summer!!! We are sure to buy even water is still cold!!! Waterproof case is good in the rainy days too!!! Hurry up please.
2019-2-16
Brainbustah
Czechia
Guys, while DJI decides when to release this water case... can I use one of these universal cases for phones with Osmo Pocket to dive into the water?
2019-2-16
v-man
Brainbustah Posted at 2-16 14:46
[view_image]
What’s so stinking hard about a waterproof case?  TSMC having trouble with the chipset? Rare earth metals in short supply?  Self driving AI bugs? Chinese union workers on strike? Dilithium crystals cracked?
It’s just a piece of plastic.  Come on now!
2019-2-22
Serb
Brazil
The point is cashing in on the hype before year's end/during Xmas when people buy all kinds of crap they don't need, all while dangling the underwater case carrot in front of all our faces, never telling us that they had no means of even producing it in time for anyone who originally purchased it to actually buy and use with their cameras.
And apparently it's easier to product this technological wonder full of processing chips, electronics, gimbals, etc... but making a plastic case for it takes months?
Get outta here, DJI...
2019-2-23
fansb032203f
DJI Stephen Posted at 2018-12-18 08:02
Hi DJI, i know you guys are working hard for Osmo Pocket waterproof case. Do you have estimated date of release?
2019-2-24
123Next >
