DJI Wanda
Hi SunaiCL, welcome to the drone world! Thank you for also detailing your questions.
For questions 1 & 2, Inspire 1 aircraft and gimbal cameras are supported by our DJI GS Pro app. DJI GS Pro can be utilized in many industries including architecture, precision agriculture, aerial mapping, electrical inspection, security control, disaster monitoring, and more; hence, you may find it useful in getting terrain data. But please be reminded that the app currently supports only all iPad Air, Air 2, Mini 2, Mini 3, Mini 4, and Pro tablets (Android is currently not supported).
For question 3, GS Pro can generate polygons, line strings, and points. These points can be used as a reference for GCP. Currently, WGS-84 is the only coordinate system supported by GS Pro.
Lastly, for question 4, there may be a different app depending on the thermal camera you are using. With DJI, we have our very own Zenmuse XT (FLIR) thermal camera which can be used together with our DJI GO app. However, placing images on a GIS map while using a thermal camera at the same time may not be possible since there is a designated app for each function.
We worked really hard to create a thorough FAQ/tutorial/manual for more information you may need. You can also find those in these links below:
https://www.dji.com/ground-station-pro
https://www.dji.com/zenmuse-xt
Hope this helps. |
