mixstreme
With no Ribbon cable we are not left with many options..... or are we?
By using this information or experimenting with your setup you are soley responsible for the outcome.
This information is in no way condoned or facilitated by DJI and any tampering with your unit will indeed void your warranty.
NEVER run your WIFI module without the antennas connected.....
I got a picture from the experimental setup on the APP from the Vision+ using the birds stock tx......etc... only a 3rd party camera used.
The original gimbal base was also still in place and allowed telemetry data to be seen on the App.....
I basically connected a cctv camera to the AV wires taken from the vision + gimbals connector (pictured)
I powered the cctv camera via a direct power lead and not through the bird as this is only to see if I could get the video....
It didn't work when connected and required me to power down the bird and then power back up, open app and hey hey, picture is there........
So FPV FIX for those that need it, using a gopro, etc.... or any camera with AV out...
***Just to be safe, you are not inputing AV into the gimbal but using the 2 wires that come from the Gimbal as pictured.........
This does not record, or work the gimbal at all, so independent recording is required for those that are looking to set this up....
Gimbal control / replacement is next on the list and going well.......
I Hope this information is useful to all the others with no FPV. Neccessity is the only reason for this workaround and I sincerely hope this helps the many who have asked...
A nice quote from a greatful user on another forum on this - "Innovation through experimentation.... You gotta love it!!!!"
