Gimbal Protected Tap to Resume
12Next >
76873 42 2018-12-20
djiuser_drone
I've only had my Osmo Pocket for one week and have only taken a couple pictures and videos. Today I turned it on and all of sudden I receive the following error. Has anyone seen this and what is the fix? I tried <reset> and gimble calibration and still the same error no luck.
2018-12-20
Ray-CubeAce
No, I'm not getting that message but that is how my gimbal is at rest when switched off. See my video on This post
2018-12-20
winwiz1959
I got the message when the camera bumped into something. I presume they want to protect the little gimbal motors. Just a tap on the screen and all was fine again.
2018-12-20
Skyler King III
Flight distance : 1387582 ft
I had the problem.  Solution:  turn pocket off.  Plug into phone and turn pocket on, and Mimo will launch. that should fix it.  If not, try another MiroSD card.  I personally advise turning pocket off before connecting or disconnecting from phone.
2018-12-20
Ray-CubeAce
Skyler King III Posted at 12-20 11:08
Thank you for the suggestion. I will try that as soon as I can.
2018-12-20
DJI Tony
Hi, thanks for the inquiry. Did the error message will disappear if you tap the screen on the Osmo pocket? Did you manage to turn off and turn on the Osmo Pocket to see if this would persist? Please keep us posted on the latest progress.
2018-12-20
djiuser_drone
No matter what I tried, the error message would not go away. The camera was never dropped or tapped. Because I was still within my 15 day exchange period. I had it replaced with a new one.
Hopefully this was a one off.
Thank you all for the replies.
2018-12-20
mareklew
Flight distance : 4026 ft
djiuser_drone Posted at 12-20 15:43
Good for you that this was solved.
Just for the reference for anyone else experiencing this problem: This message means, that the Osmo could not move gimbal with its own power for some time. It is not about hitting an EXPECTED physical limit (the gimbal does not turn 360° and Osmo knows where the stops are). It will pop up if you lay Osmo down when powered on (the gimbal movement will be restricted and Osmo will not be able to move it).
If you get this error when the gimbal is not touching anything you may have the following issues:
1)  some debris between gimbal parts (like a grain of sand or a breadcrumb) - try moving the gimbal by hand with power off, it should move butter smooth without almost any friction. If not, see if you can **gently** pick the debris out
2) wires to one or motors are damaged -> camera needs to be repaired
3) some other failure within camera (accelerometer providing false readings, power stage of one or more motors failed, etc) - anyway repair is impossible at home
2018-12-21
Gloria Liang
Did you guys get this fixed? I'm having the same problem.
2018-12-22
Skyler King III
Gloria Liang Posted at 12-22 14:11
Try my solution posted above.  Let me know how it works out
2018-12-22
szabi510
Hungary
I've the same problem... I tried many things but nothing... Firmware update was very difficult but successful.
Any solution or must be change another one?
2019-1-5
djiuser_Aec5CDJfBKGi
Flight distance : 6246378 ft
Brazil
I have the same problem, we tried all the procedures informed and nothing to solve.
The error message continues and you can not use it.
2019-1-17
Chris Casila
cgbrian.com Posted at 1-7 18:14
I went through 3 exchanges while noticing a click on the pitch axis. I finally resolved the issue myself by lightly squeezing the "hinges" on the pitch axis and rotating the pitch manually back and forth (while off).. the click or light crunch goes away and the camera is smooth.. I had tried 3 units before deciding to monkey with it a little.. Point is.. there is a little resistance from the wires inside binding.. and a little squeeze while moving it back and forth (pitch) clears it up
Thank you mister. This worked for me.
2019-1-29
El Diabolico
Had the message briefly when trying to fit an ND filter. I guess it is there only to avoid unnecessary strain to the gimbal motors...
2019-2-4
fans31013411
Taiwan
Hi guys, I’m also facing the same issue, the gimbal kept turning and the error message “Gimbal Protected, Tap to Resume” pops up. After tapping, the gimbal starts turning again and the whole cycle repeats. I’ve tried updating the firmware, resetting, calibrating but it all doesn’t seem to work. I’m using this to film an event next Thursday and I can’t afford for it to fail on me now anyone has a solution to solve this? Or must I have it sent in for repair? The DJI online support
2019-3-23
Tan Cyang
Iceland
fans31013411 Posted at 3-23 04:15
I'm currently having this problem now while having honeymoon trip with my wife, all you can do for emergency was to "assist" the gimbal to move up and down during the turn on period. Desperate time calls for desperate measures .
2019-3-24
djiuser_FbPKDfQL7Nep
India
Even I am facing the same issue today. It started while upgrading to new firmware. Any solutions ?
It says " Gimbal protected. Tap to resume ". Unable to fix it.
2019-4-2
Wiz33
Flight distance : 35994 ft
djiuser_FbPKDfQL7Nep Posted at 4-2 10:39
Do a calibration
2019-4-2
Stuge234
India
Emergency solution given here
2019-4-2
Yulongxie
After checking the past post, it seems like I am not the only unlucky guy to have this issue.  I ordered the osmo pocket on April 15, 2019, got it on April 18, first use in the weekend of April 20, 2019 with a few more uses in the following weekends.  The “gimbal protected, tap to resume’’ came up suddenly in this past weekend without any incident which could lead to possible physical damage and did not go away no matter how.  Double or triple clicking the power button sometimes did not do recenter or flip.  Sometimes image was shaking and I could feel the motor was vibrating.  Calibration always failed since then.  The ‘gimbal protected, tap to resume’ prompted frequently no matter which mode I was using.  I filed online service request on May 19, 2019 and will send the unit back for repairing after current travel.
2019-5-20
Irsan
Indonesia
Any solution yet beside the video?
2019-6-6
djiuser_RuWaY9MzLmaD
Malaysia
I've fixed mine. The video is on my youtube channel hope that helps. youtu.be/cz75q3xmV8s
2019-7-17
djiuser_v5ntU5nKtsQ1
Belgium
Chris Casila Posted at 1-29 08:36
Tried all the other solutions and only this one worked for me. Thank you !
2019-7-22
djiuser_0xcGbJFZKY2I
Thank you Chris that worked for me too. I’m currently here in africa about to shoot some nice settings and could not get this fixed until I tried to squeeze both sides of the gimbal and rotate it a couple times. Had to leave a review.
2019-9-15
djiuser_hfG5UMdYobVo
How did the service repair go? Anyone?
2019-9-28
Melissa Alhambra
I'm currently having the same problem with gimbal and tap to reset. It seems that the gimbal is stuck on the other side when it turns. What do I do?
2019-10-1
djiuser_AyvZeZmuW2TC
I’ve got the exact same problem. I can’t believe it’s only 2 weeks old and I can’t use it for the last 2 days of my holiday.
I guess I need to send it back #disappointed
2019-10-4
fansca756200
I have had the same issue where the gimbal becomes stuck  on startup when it turns and then received the error message above.  No drops, always stored in included protective case in between usages.  Barely used.
Sent it in as per DJI online support and received an invoice for repair that was half the cost of the DJI Osmo Pcoket!!!!!  Only explanation I received was the gimbal was fragile and small things could have caused the damage.
Has anybody had any success with DJI on this very common issue?
2019-10-14
Getgo_Mike
I've got a simple fix for this. Hold the Pocket upside-down as you power it on. It should work every-time...
2019-12-11
fans5281c899
I am having the same issue
I notice the camera when turnng it rubs the bottom of the base
Any of you having that issue as well
2019-12-29
Tonka9
Flight distance : 4114 ft
I squeezed mine a little and used compressed air before hand.  Worked like a charm.
2020-1-21
J-G-P
I have had the same problem today, when the camera was in the waterproof case and at various depths from 2m to about 8m.  I could reset by turning off, but as soon as I pressed record, the message came back.  Oddly, enough I was not willing to take the camera out underwater and  'tap to resume'.  Upon surfacing, everything was fine.  Weird !!!!
2020-2-25
blabel75
I am having the same problem. Camera was working fine and then all of a sudden when I turned it on it produced this error. I notice when trying to rotate the gimbal the 180 degrees counterclockwise (with the power off) it only has about 30 degrees where is rotates smoothly and then the rest of the rotation has a lot of resistance. So I suspect there is either something stuck in there or a problem with the motor that rotates the gimbal. Not sure if there is an easy fix for this or more likely a repair service is needed.
2021-1-26
blabel75
blabel75 Posted at 1-26 18:08
Okay. I opened a case to send in my Osmo Pocket for repair. But today I was looking at it and decided to try to see if I could get it to work. after turning the gimbal several times, it now works! Now, is there any way to close a repair case? Or will it just expire at some time?
2021-1-29
JPW1
Flight distance : 53323 ft
I'm running into a similar issue, but probably worse.  The motors all appear to move freely.  I can set mine up on a tripod or just flat on a table and start recording.  So it is perfectly still.  After about 3 - 6 minutes, the device just decides to go into gimbal protected mode for basically no reason.  Has anyone possibly seen this kind of issue before?  Any idea what the resolution was?
2021-2-13
djiuser_jGQUSgKpYWdn
Skyler King III Posted at 2018-12-20 11:08
I've tried every step you suggested.. didn't work... I'm kinda bummed...
2021-5-10
derkjickface
djiuser_jGQUSgKpYWdn Posted at 5-10 13:18
Chris Casila thanked a cgbrian.com who Posted at 1-7 18:14
"I went through 3 exchanges while noticing a click on the pitch axis. I finally resolved the issue myself by lightly squeezing the "hinges" on the pitch axis and rotating the pitch manually back and forth (while off).. the click or light crunch goes away and the camera is smooth.. I had tried 3 units before deciding to monkey with it a little.. Point is.. there is a little resistance from the wires inside binding.. and a little squeeze while moving it back and forth (pitch) clears it up"
I found the above to be my ONLY solution.  I gently squeezed the two sides for a second and turned on the device and the same error appeared.  I turned it off, gently squeezed again with a little more pressure for two seconds.  Turned it on and VOILA!  Gimbal Protected error was gone!
Thanks to Chris Casila and cgbrian.com for posting because I too was bummed and I REALLY enjoy the DJI pocket gimbal camera.
2021-6-21
fans66c29fdc
Stuge234 Posted at 2019-4-2 11:01
https://www.youtube.com/watch?v=LyDX7VH5fjQ
This solution worked perfectly! Thank you for the help!
2021-9-23
djiuser_sx0aaKCpZVnC
India
I also met with the same problem it's hardly 20 days that I bought the camera.i cannot find a solution yet as there is no repair centre any where near...
2021-11-11
djiuser_85j8Ngie9pGo
Belgium
I had the same issue where the screen kept showing the gimbal protected message without prior incident. I had my unit replaced already once for gimbal problels and I was really disappointed at this moment that I would loose again my pocket 2 for a whole month in repair.
Upon checking myself the gimbal more closely (while off), i noticed there was some resistance at a certain point in the pitch. Looking from behind it was clear that - what I initially thought was debri - a tiny flat cable that was causing the resistance. I fixed it myself by gently pushing the flat cable back inside.
I still don’t know how this could have happened but I think it could have also been prevented if the cable was fitted a bit more firmly in place. I’m really happy with the pocket 2 but man these things are extremely fragile even for one that takes good care of his gadgets.
2022-2-12
12Next >
