Side to Side Shake
590 9 2018-12-22
GeorgeMC
Flight distance : 90515 ft
Hi
I am using a Ronin s with my Canon 5D Mkiii and a 16-35 mm Canon lens.
There is an annoying side to side shake in any video I do.
I have the latest firmware updates and the Ronin app says that my balance test results were excellent for Yaw, Roll and Pitch
You will notice a slight side to side shake throughout but more prevalent at the very end.
Thanks
2018-12-22
fansa605563a
Flight distance : 11778 ft
Try Auto Tune under Motor Parametrs  if you havent already.
2018-12-22
GeorgeMC
fansa605563a Posted at 12-22 16:49
Yes did that already. Did not work. Thanks!
2018-12-22
Fjord Pro
Flight distance : 1612215 ft
Norway
Hi George, having the exact same problem. Makes the Ronin S totally useless at the moment. I've updated firmware, gone through all the settings etc, still the same problem. Have you gotten any feedback or fixed the problem? I'm using the Ronin S with an Panasonic GH-5 and even with the in camera and in lense stabilisation it´s as visible as in your video.
2019-1-21
GeorgeMC
Fjord Pro Posted at 1-21 10:30
Hey Fjord
This was a response I received form one of the DJI moderators: "Well received, for your situation, please try to auto tune and recenter to check the motor parameters. If the gimbal drifts when shooting still, please do system calibration and joysticks calibration to see whether it works".
I checked it a couple of weeks ago and it seemed to have worked after performing the system calibration. I only did a quick checks with a couple of short clips. Honestly I think more testing needs to be done and I have not had the time. But the few short clips seemed to be a lot better.
Good luck.
2019-1-21
Fjord Pro
Norway
GeorgeMC Posted at 1-21 19:52
Hey Fjord
Ok, thanks George. I'll try to do the same and se how we go. Thanks again
2019-1-22
GeorgeMC
Hey Fjord
Well, after more testing this is still not working properly.
I'm really getting frustrated and am getting to the point of trashing this!
I can do smoother video holding the camera in my hand
This test video was done standing still and not walking. I have all the updates and the balance check was excellent.
I need to resolve this issue. A friend has another gimbel from a competitor that works beautifully. This one is really  giving me issues.
2019-3-1
GeorgeMC Posted at 3-1 14:32
Hi GeorgeMC, a properly balancing the pan axis will result in a side to side wiggle when the gimbal is trying to stabilize the camera as you walk. To check whether your pan axis is balanced properly, take something like the included charger and place it under one of the tripod legs and hold the handle. With your other hand, go into the App and run the balance test. All 3 axes should be Excellent if properly balanced. Please check more details here: https://forum.dji.com/thread-182599-1-1.html
2019-3-3
GeorgeMC
DJI Mindy Posted at 3-3 22:38
Thanks Mindy I've tried that and all 3 axes are reading excellent. I've contacted support and am thinking this may have to be sent back for service. It has not worked well since I got it. I have always assumed it was just user error but now I'm thinking it's something else. It's almost a year since I purchased it and have tried just about everything at this point.
So far I'm pretty disappointed in it and I hope that it can be resolved to restore my faith in the product.
Thanks
2019-3-4
GeorgeMC Posted at 3-4 06:09
May I verify more details?
1. Do all the knobs in the gimbal have been locked tightly?
2. Did you mount the camera mounting plate and the lens support properly?
3. Please try to increase the Stiffness value after the Auto Tune to see if it works, thank you.
2019-3-4
