MA flying sideways during Litchi mission
3311 9 2018-12-22
Christine96
I can't seem to figure out how to set waypoints in Litchi so that my drone doesn't fly sideways as it approaches the next waypoint.  Here's my latest video and though it's pretty good it flew sideways at a few waypoints.
2018-12-22
OneDoesNotSimply
Flight distance : 662644 ft
Have you tried changing the path mode to "Straight Lines" in the Settings on the bottom left? I assume you are using the Litchi Hub: https://flylitchi.com/hub
2018-12-22
Christine96
OneDoesNotSimply Posted at 12-22 15:05
Yes the Litchi hub.  I think I tried that but seems like the drone would stop momentarily to change direction so I started setting curves.
2018-12-22
OneDoesNotSimply
Christine96 Posted at 12-22 15:15
Ah, gotchya. My only other suggestion is to play around with the Heading Mode in the settings.
Heading Mode: Defines the heading of the aircraft during the mission. Choose between "Toward next Waypoint" ("Auto" on iOS) where the aircraft will point toward the next waypoint, "Initial Direction" ("Initial" on iOS) where the aircraft will keep the heading it has when the mission is started, "User Controlled" ("Manual" on iOS) where you are able to control the heading of the aircraft during the mission using the left joystick left/right (mode 2) or "Waypoint Defined" ("Custom" on iOS) where the aircraft will use the heading defined at each waypoint. Using "Waypoint Defined" ("Custom" on iOS) also means that the aircraft will smoothly transition from one waypoint's heading to the next.
2018-12-22
Bluehook
Flight distance : 790814 ft
I'm new to Litchi and experiencing the same thing.  What is happening, I presume. is this:  the drone is anticipating where it is told to be pointing at the next waypoint and smoothly turning in that direction.
I'm getting around this by adding more waypoints between my existing waypoints, thereby adding more finite instructions for the drone to perform.
But again, I'm am certainly no expert, but @dirtybird is, he could probably explain this much better.
2018-12-27
Christine96
Bluehook Posted at 12-27 10:52
I started using TNW and now I don't have that problem anymore.  It keeps the nose pointed forward and when it goes around a curve the nose follows the curve.
2018-12-27
jimmylee
Flight distance : 367352 ft
Yes that is exactly what is happening.
Just add more waypoints so it does not turn till the last moment.
2018-12-27
Zigenbock
Flight distance : 189341 ft
You can also add some POI and have the drone point to them so that it move smoothly between waypoints.
2018-12-27
Albermen
Flight distance : 39196 ft
By adding more waypoint, it will reduce sideways when it turn?
2019-1-4
quaddron3
Play around with Heading Mode in the global mission setting.
If you have to, do User Controlled heading mode, and manually set the drone direction to look in the direction of flight to the next waypoint. Then once the drone reaches that waypoint it will rotate before flying to the next waypoint, etc.
2019-1-4
