Image breaking up screen turning green
1338 11 2018-12-23
Franko
Flight distance : 23255 ft
The image on my ipad mini is breaking up and turning green even when it is within a few feet of the P4. I also tried a Samsung Galaxy tablet and that was even worse. The videos and pictures on the Micro SD card are perfect so its just the screen. Very, very anoying while in flight. I'm thinking it is a transmition or refresh rate setting. Can someone help me with this.Thank you
2018-12-23
DJI Natalia
Hi Franko. We're sorry for the trouble caused. Can you please try to refresh the firmware of your drone via DJI Assistant 2? Also, kindly make sure that the firmware of your iPad is updated to the latest version. Try to re-link your iPad to the drone. If still no luck, try to uninstall and reinstall DJI Go 4 App and let's see if this will work. Please keep us posted for further help.
2018-12-23
Franko
DJI Natalia Posted at 12-23 08:38
OK I'll try all that and report back once it has all been done.
Thank you
2018-12-23
DJI Natalia
Franko Posted at 12-23 10:02
Thank you
No worries, Franko. Take your time.
2018-12-23
Phantom Rebel
Flight distance : 174 ft
I had the same issue and it turned out to be the processor for the tablet, its too slow, hence the green screen.
I upgraded my iPad mini to a higher processor and have no issues since doing so.
2018-12-26
ALABAMA
Flight distance : 10442687 ft
Phantom Rebel Posted at 12-26 03:58
Exactly the right solution.  The apps have gotten pretty power hungry.
2018-12-26
Tuscani32
Flight distance : 6049741 ft
Norway
Phantom Rebel Posted at 2018-12-26 03:58
I USE the IPad 4 mini and have the same trouble. I have also tried other tablet, but this has ben the best so far. Thought the iPad 4 mini had a fast enough prosessor.  I have ordered arrangement extender hopefully IT will help
Happy for suggestion what to do
2019-1-9
Tuscani32
Norway
2019-1-9
Tuscani32
Norway
2019-1-9
DronePilot_01
Flight distance : 817713 ft
The problem can be caused by overheating due to an overladed CPU. Some users reported that turning off caching of video resolved the overheating problem. The real cause of the problem is that the DJI Go app is optimized for the latest, fastest iPads and the iPad Mini is badly in need of an update and underperforms the full sized iPads. I recommend switching to the larger iPad.
2019-1-16
Tuscani32
Norway
I have same trouble Ipod4 mini. Bought the 9,7" Ipod with the faster prossesor, same trouble, bought range extender, same trouble, so I will carefully follow this link. Hopefully somebody can come up with a good idea. I have set my camera to automatic.
2019-1-25
Franko
Tuscani32 Posted at 1-25 07:32
Same here. I have tried everything. Thinking of buying the DJI goggles but theyre too big and bulky.
2019-1-26
