Seems the new one I purchased from Best Buy today just starts up and never gets to the registration/activation screen on the phone. Goes straight into the app and everything appears to work. Does not even ask for a firmware update.
Did I get a unit that someone had activated and returned? How do you tell? If it was a Phantom or Mavic I know this would be the case.
DJI Tony Posted at 12-24 13:53
Hi, thanks for the inquiry. May we have the serial number of your unit via PM for further help. Thank you for the support.
Thanks DJI Tony, private message sent.
BTW - it is already on Firmware 01.02.00.20
Forgot to mention in my first post that it only took 25 minutes to charge the battery and I was only using 1 amp.
DJI Tony Posted at 12-24 18:43
Hi, thanks for providing the information. May we know if you manage to test the performance of your Osmo Pocket on how long it will last?
I have re boxed it and plan to return it after Christmas if it has already been activated.
EdM Posted at 12-24 19:09
Shame I won't be able to use it tomorrow.
Hi, thanks for your reply. We will forward this information for further help. We will keep you posted once we've received feedback from our team. Your patience is highly appreciated.
DJI Tony Posted at 12-25 09:06
Thanks Toni, will hold off on taking it back til I hear from you.
Hi, thanks for providing the information. We will keep you posted as soon as we received the feedback. I would recommend contacting the re-seller as well to determine what is there after sales policy for return product for you to be aware.
DJI Tony Posted at 12-27 12:47
Had no problems exchanging it at Best Buy. After seeing the original packaging I know for sure it was a return. Activation and update worked absolutely flawless. I even found out I could use a USB-C to Lightning cable and hook from the bottom of the OSMO Pocket to my iPhone and it works.
