Case interferes with DJI Smartphone Adapter
1560 12 2018-12-26
ironicgull68
Hey all,
Anyone notice that it’s virtually impossible to have a phone case? Solutions? I was thinking of picking up a Spigen thin case.
Also, anyone realize that the plus size phones have a noticeable pull on the device that makes it look like the adapter is about to snap? Maybe it’s just me.
Leave comments or suggestions below please!!
JN
2018-12-26
DJI Gamora
Hi ironicgull68, sorry for the confusions. There is no problem with putting up a case with your mobile device as long as it is not thick or the design of the case is not unusual. Kindly reach us again if you have concerns. Thank you for your support.
2018-12-26
ironicgull68
What do you mean? I’m using an otterbox symmetry case and it seems as though all DJI had to do was add 1/8 of an inch to the adapter for it to work. Unfortunately, I enjoy having the protection of a phone case so now I have to get a new case or pay to fix my broken phone every time I use this device and potentially break my phone.
Will there be an accommodation for this in the future or could you provide a specific case that is usable for my purposes, while also protective.
JN
2018-12-26
DJI Gamora
ironicgull68 Posted at 12-26 09:37
Hi ironicgull68, I will be introducing this to our R&D's for them to be notified and see what they can do. As for now, I know that this protective case is important to you. If using the otterbox symmetry case is hampering the adapter, just remove it for you to be able to use the Osmo Pocket efficiently. Thank you.
2018-12-26
ironicgull68
DJI Gamora Posted at 12-26 09:43
Ok but you’re not understanding I don’t want to have to remove it
I was asking if you know of a case I could get that would work.
Thank you for notifying researchers and developers
2018-12-26
CruiseHabit
Flight distance : 93225 ft
Would definitely like to see a USB-C connector that sticks out just 1/8" more so that I could use the device with a case +1
2018-12-26
DJI Gamora
ironicgull68 Posted at 12-26 09:46
Hi, I understand you don't want to remove the case. But if using the phone with this case and hampers the adapter, then you may remove so for awhile when using the Osmo Pocket. Apologies but I don't know a specific phone case that would fit in to your mobile device. Thank you.
2018-12-26
ironicgull68
CruiseHabit Posted at 12-26 09:48
Maybe enough +1’s and theyll make one, for now check out spigen they make a thin fit and liquid air case that I will test out.
2018-12-26
Rogue0ne
Flight distance : 30322 ft
I’m just waiting for the WiFi and Bluetooth adapter.
2018-12-26
ironicgull68
Rogue0ne Posted at 12-26 12:48
True, I’m also looking for a possible alternative using a usb c to lighting cable, may make it more usable. The other idea is the use of a usb c ported microphone. This would allow vloggers a microphone without the DJI 3.5 mm attachment
2018-12-26
ironicgull68
ironicgull68 Posted at 12-26 13:15
I’m going to make a video comparing a pro shotgun or lav mic vs the Osmo mic. I found attachable wind screens, look up micromuff on Amazon. Very useful
2018-12-26
Onsomehill
iPhone X and Tech21 Evo Mesh case works just fine with my OP.
2019-2-8
djiuser_lqb0vCNCKiT2
Hello! I just purchased the DJI wireless mic to use with my 23 ultra, and unfortunately I have found this issue is effecting me as well. The phone must be removed from the otterbox to be connected. Has any kind of longer C port connector been made available for purchase yet, Or does anyone have any suggestions? Thank you! *Update: nevermind! A pair of wirecutters did the trick!
2023-4-6
