djiuser_kaVZlZOaTqIl
Flight distance : 1695351 ft
Lucas775 Posted at 12-27 20:19
Just go out and buy an SD card on line, meanwhile you can use the internal 8gb memory.
Its in, extremeplus64, app wants to bloat galaxy s8 internal 64gb meant for phone with over 2gb dji hotel loads. Weird, prior buying sandisk for ma the screen interrupted to write to s8's installed sdcard because it too is extremeplus64. So i pathed writing into s8 sdcard. This means dual writing in real time? One into ma and one into s8 sdcard? What we want is one write into ma sdcard. It would be redundant writing to ma and s8 same data. This conserves processing equiv power savings? Trivial writes? Can the installed sdcard in ma be accessed by external usb jumpdrive (passive portable storage) via the same rc port the s8 uses? Or must s8 be connected for app with ma connected to rc via ma "s" connect port and rc usb connect port? Or, you gotta access via usb cabled chromebook, android s8, macintosh, windows, ? Then pruning the ma onboard storage can be done. For improve, can dji code app for user enabled auto move off from factory 8gb into ma sdcard? |
