EdisonW1979
Flight distance : 1535679 ft
A.V.hiflyer Posted at 12-30 23:39
zero degree's and visible moisture is the recipe for icing...sometimes a little and sometimes a lot ...airmanship 101 but I'm not being snide..It's easy to forget and sometimes the clouds are dry enough that you can get away with it. Hope you are able to fix the antenna..I sent mine back to the factory for the over-center spring on the antenna and it was costly. 170 I think
Agreed, even with the Mavic 2 series with its -10c flight rating, that’s only if it’s a dry sub-zero without visible moisture... If you’ve watched any documentaries, or are a fixed wing pilot otherwise, you’ll know that any moisturized air travelling over a metallic, composite, or plastic surface at sub-zero has a much higher chance of forming ice crystals and bonding to the aircraft, which can spell disaster.
In fact, DJI I believe specifically state not to take the AC thru any clouds or fog banks, as even if the temperature is above freezing, the chances of the moisture getting into the aircraft electronics and/or motors and causing issues during flight is much higher than in standard flight. |
