fans4d376b39
Flight distance : 2041 ft
Hi.
I am running the A3 on a custom built platform with ESC and Batteries that are not DJI's and it flies very well. When I do the setup for the A3 in the DJI Assitant 2 and put in other ESC's and Batteries I can only get a voltage of the packs (which is fine). The problem I am having is when I set the low battery voltage warning to a safe voltage for the batteries in the A3 and highlight the Return To Home when it hits that voltage or low voltage in the software it does not return home. It will just go right past the low voltage warning I set and keep flying. I can press the Return to Home on the controller and it will come home. Am I doing something wrong? Please help and thank you.
David
