fans4eb33ea9
Flight distance : 47418 ft
WebParrot Posted at 12-28 17:01
Nice job. A few thoughts/suggestions. If you can find a way to remove some material it would keep the device from holding in heat. After 5-10 minutes of video that body gets pretty warm and you need to release some of that heat to prevent damage to the works. And if possible, find a way to give the adapter more clearance for phones with cases. As shown it seems a bit shallow.
Very nice effort and outcome.
Good ideas, definitely I will put some "vents" on the sides. I was going for maximum stability in my design.
RE phone connection, I don't think I can change it, I latch on the lighting connector to have a safe hold and the device can not dislodge even if it is inverted. Maybe I can make the tab 1mm thinner but it will be too easy to break I think. |
