Duca
lummox Posted at 12-30 03:52
I’m not sure what “snodable” means, but you can use a cable to connect your phone to the camera. You might need to use an adaptor, unless the cable has usb-c on the camera end. Also, the upper phone adaptor needs to be pointing out. Hope this helps.
Hi lummox,
when you link your phone to Osmo, you can NOT rotate it, so what you see in your phone screen is exactly what you see in the in-built small screen of the Osmo.
If we could instead rotate it, we can use Osmo in any situation checking what are you filming by orienting smartphone screen.
Yes, you can use a USB-C cable but you need a Rig or e Mount to fix you smartphone to the Osmo. |
