Bunraku
Flight distance : 4583 ft
Vermifuge Posted at 12-31 02:55
The osmo line of cameras are finicky beasts....
You need a proper ND filter to get correctly exposed video. The Osmo cameras have a wide option aperture. As a rule of thumb, always have the histogram view on screen. 1. Record in manual mode. 2. Pick the desired resolution and frame rate 3. Set the shutter speed to 2x the frame-rate. (in the case of 24/48FPS choose the nearest option) 4. Set the white balance (auto is OK but manual will be better) 5. Apply the correct ND Filter... When applying a ND filter refer to the histogram, use the filter that brings the histogram peak to the center of the meter. (not shifted too far left or right) Follow these steps you should get nice clean and bright video...
Thanks Vermifume.
I put a faster write speed Micro SD card in and changed the shutter speed to 60 using UHD at 30 FPS. Picture is much much improved. I've attached a video with 3 parts.
1st part is Auto White Balance.
2nd part is Cloudy White Balance
3rd part is Cloudy WB and also Vivid colour.
I don't have any ND Filters yet, but they are coming.
I still have 2 issues I don't know if you can help with.
1) I use Powerdirector for video editing and never had an issue with editing before.
However if you look at around 11 seconds at the bottom of the tree you will see some compression/distortion. This is not in the raw footage.
2 When I upload to youtube the compression is terrible. There is really bad distortion and the video is unwatchable. Any idea whats the best settings?
Thanks
