Mark The Droner
Flight distance : 2917 ft
Yes - the SE is a unique system. Know that the working antennas on the SE are hidden inside the controller and facing forward. For example, if you're flying straight up (not recommended), you should position the controller so it's vertical and the front is pointing straight up. If you're flying low towards the distant horizon, you should position the controller so it's horizontal and the front is pointing towards the same distant horizon. The little stick antenna on top is of no consequence.
Good luck |
