what will the government do about Drone safety!!!
1008 13 2019-1-1
TC KABREW
Austria
i think personally that the government will enforce the no fly zone with new firmwhere which will disable the drone if it enters no go zone, and i think they will have other drones that will have a net shooting devise to disable the infringing drone but that wil be a last resort.
2019-1-1
Lamplighter55
Flight distance : 538596 ft
NFZ is already implemented on DJI consumer drones. The most likely enforcement will be drone registration and in-air identification. So the majority of drone users will by default be unlikely to fly into a NFZ by design or accident. However this won't be the case of those who have breached the software license and hacked the flight software to circumvent the safety defaults etc. So as a possible insurance against these - sensitive facilities will probably be investing in active disabling technologies - through either signal disruption or physical capture.
2019-1-2
TC KABREW
Austria
Lamplighter55 Posted at 1-2 07:57
ok, you definitely know more about this then me
2019-1-2
DJI Tony
Hi, thank you for sharing your thoughts here. The application itself will provide the information if any case that the drone will be located with restriction areas. There will be different levels depending on the locations. Red zone will lock your drone down and prevent you from flying it due to that it's not recommended to fly your drone in the specific area, however, if you believe that you the right to fly your drone with the location then you could reach our team to possibly unlocking the location by sending an email which is flysafe@dji.com. You could also check our restrictions level using the link below. Thank you for the support.
https://www.dji.com/flysafe/geo-map
2019-1-2
TC KABREW
Austria
DJI Tony Posted at 1-2 14:52
Hi, thank you for sharing your thoughts here. The application itself will provide the information if any case that the drone will be located with restriction areas. There will be different levels depending on the locations. Red zone will lock your drone down and prevent you from flying it due to that it's not recommended to fly your drone in the specific area, however, if you believe that you the right to fly your drone with the location then you could reach our team to possibly unlocking the location by sending an email which is . You could also check our restrictions level using the link below. Thank you for the support.
K thanks for the info
2019-1-2
remotepilot101
India
Faa has already made many safety measures for drone flying, which you can check here:- http://www.faa.gov/uas/where_to_fly/airspace_restrictions/
If anyone here looking to qualify a FAA UAS Knowledge test, then you can take FAA Part 107 Study Guide from remotepilot101 and pass your test.
2019-1-3
TC KABREW
Austria
remotepilot101 Posted at 1-3 02:09
i meant they will make it harder to hack and change
2019-1-3
DJI Tony
TC KABREW Posted at 1-2 15:13
You're most welcome Tc Kabrew. Please let us know if you have other concerns.
2019-1-3
TC KABREW
Austria
DJI Tony Posted at 1-3 08:10
okay will do
2019-1-3
TC KABREW
Austria
Tony
is there anyway to make forum points quicker then just replying to things.
2019-1-3
hallmark007
Flight distance : 9827923 ft
TC KABREW Posted at 1-3 08:47
Tony
Post  some video/photos if you get a digest you will gain 600 pts, also enter some competitions these also offer extra points.
2019-1-3
TC KABREW
Austria
hallmark007 Posted at 1-3 08:59
what is a diggest
2019-1-3
Lamplighter55
Today the UK's two main international airports have announced they will both be investing around £5 million each in 'anti-drone' technology.  Basically directed signal jamming tech. in the most.
2019-1-4
TC KABREW
Austria
Lamplighter55 Posted at 1-4 08:01
yh, i wonder if they will make drones with nets on to catch the drones.
2019-1-4
