CycleParadise
Flight distance : 385338 ft
Jyunte Posted at 1-4 17:41
I use the MavMount also. You can set it up so that it doesn't block the controller's screen, but as others already said, all the information you need is on the Go 4 app, so you don't need to see the controller at all. If you feel you really need to see it, simply tilt the controller towards or away from you and look around the tablet's screen... There's plenty of space there. I use a 10.5" iPad Pro.
Thanks Jyunte!
As you and others have been suggesting, maybe I need to become more comfortable with not having to look at the controller screen as the information I need is displayed in the Go4 app. Should I lose connection between the controller and app (which has happened in the past bu not recently), I could look over/adjust the phone/tablet to see the controller screen. |
