Apologies to all who viewed and or replied. I clearly confused My Story for Story Mode.No need to reply or post condescending remarks. Grow up ... if that's a possibility.
There was no malace intended... simply an error on my part.
No No NO ! You did NOT understand what the originally advertised story mode is. You've never used Tiktok before, Do you? What you've seen is the default function from Tiktok code.
What the store mode advertised by DJI, in the past, is .... Check the video,Check around 0:58 . You determine what kind of movie effect you are shooting, then the osmo pocket shoot it with the predefined Motion effects. It the function to let the gimbal lens automatically move based on your PRE-defined mode.
Hi, thanks for the inquiry. We've provided the information in regards to this query on another thread. You may refer to the link below. Thank you for continued support.
DJI Tony Posted at 1-3 16:54
Even trying to operate my story you get to the part where it asks to import from sd card but it won’t allow you to import from so card, just says tap to import from sd card but it’s a dead button.
