Tilted Panorama Not possible
1256 11 2019-1-5
c3rr
Austria
I really like the panorama feature on the osmo, unfortunately I am not able to make a panorama in a upwards or downwards tilted view. When I shoot the panorama, the osmo recenters it's tilt to zero degree, before it starts capturing the images.
Can someone confirm this behavior?
2019-1-5
Ray-CubeAce
Yes. Confirmed.
I for one am thankful for that. Not having to worry about level horizons or leaning verticals. So much easier than having to work with wide angle lenses. Not that it always works. Horizontal elements can bend quite badly and some diagonal elements within a frame have a mind of their own.
I'm sure there must be a reason for your question but I suspect the pocket doesn't allow it so that the gimbal is always within its own scanning range.
2019-1-5
c3rr
Austria
Ray-CubeAce Posted at 1-5 05:33
Yes. Confirmed.
I agree in some situations it is very useful. But when you are for example in front of a higher building, then the top of the building is not on the panorama and the lower half of the panorama is mostly the floor.
It would be nice if DJI could unlock the custom tilt, at least in Pro-Mode to allow more creativity.
2019-1-5
c3rr
Austria
I just realized that in FPV-Mode the osmo pocket does not recenter before the panorama shots, which enables custom tilted panoramas
Nice job DJI!
2019-1-5
DJI Natalia
c3rr Posted at 1-5 08:56
Hi there. Thanks for sharing your feedback and suggestion with our new Osmo Pocket. With regards to your concern, I'll forward this suggestion to our R&D department for future update. If you need any help, please don't hesitate to reach us. Thanks for choosing DJI.
2019-1-5
c3rr
Austria
DJI Natalia Posted at 1-5 11:20
Thank you! But I just found out that it is already supported. But it is not so obvious. You have to set the Osmo Pocket into FPV-Mode, then it makes panoramas aound the last viewed position (including tilted positions). In all other modes (including follow mode) the osmo recenters it's tilt to zero before the panorama starts.
It might be useful to write this into the FAQ or something, because I am sure that many people are not aware of that.
2019-1-5
Ray-CubeAce
c3rr Posted at 1-5 11:46
Can you post an example? I tried and can't seem to get it to work.
2019-1-5
c3rr
Austria
Ray-CubeAce Posted at 1-5 12:28
Sure. Here you see a 3x3 pano facing down outside of the window.
This is how I made it (without mimo-app):
1) go to panorama mode
2) swipe up the touchscreen an change the right-bottom located button to "FPV" mode
3) move your osmo to the desired location and press the trigger. Then it starts making photos around this position
2019-1-5
hallmark007
Flight distance : 9827923 ft
What your looking for maybe better suited to manual pano shooting it’s pretty simple and can return great images.
2019-1-5
Ray-CubeAce
c3rr Posted at 1-5 12:40
Huh! I thought I'd tried that earlier and it didn't work, but just tried it again and it did. Thanks!
2019-1-5
nlam514
[Image]
Thank you for the heads up! I ran into this when I was trying to take a pano of a Christmas tree close up. Doesn’t matter how much I tilt the Osmo Pocket, it keeps going back to the horizon.
2019-1-5
fans3d974efb
Flight distance : 389199 ft
c3rr Posted at 1-5 09:23
Nice job DJI!
Thanks for the FPV tip I can now compose panoramas exactly how i want them
2019-1-5
