DJI Assistance is not working
964 11 2019-1-5
Ger8
Flight distance : 56555 ft
Have downloaded the new Assistany 2 version 1.2.4., connected Mavic Air to PC.
Its not doing anything even I installed it without Virusscanner.
Have someone a idea how I get it working?
I run Windows 8.1.
2019-1-5
DJI Gamora
Hi there, thank you for reaching out and we're sorry to hear about the trouble, with regards to that when you try to plug the aircraft to your PC the DJI Assistant 2 won't recognize the Aircraft? If that the case I would suggest disabling the Driver Signature Enforcement on Windows.
2019-1-5
Viking-Ger
Thank you for swift reply, have tried it but think that the BIOS set-up prevent changing driver signature enforcement.
PC is a Dell.
2019-1-6
Viking-Ger
Have installed version this version DJI Assistant 2 1.2.2.859 2018_03_09 signedwin7win10.exe with success.
2019-2-11
DJI Tony
Viking-Ger Posted at 2-11 23:53
Hi, thanks for the prompt reply. May we know if the concern has been fixed by installing this specific version of the DJI Assistant 2? Please keep us posted on the latest progress. Thank you for continued support.
2019-2-12
Viking-Ger
DJI Tony Posted at 2-12 14:49
Good day Tony,
Correct, have installed mentioned version and it's recognising Mavic Air and controller, all features are working.
2019-2-12
DJI Tony
Viking-Ger Posted at 2-12 23:59
Good day Tony,
Hi, we're sorry about the troubles that you had in regards to the calibration. However, we're glad that everything went well. Please don't hesitate to reach us if you have other concerns. May you please have a safe flight always! Cheers!
2019-2-13
HedgeTrimmer
DJI Gamora Posted at 1-5 09:22
I would suggest DJI needs to get Assistant-2 (and it's drivers) officially authorized by Microsoft and Apple.
The work around of disabling the Driver Signature Enforcement, should have been just that a "work around", for initial release of Assistant-2.  Not a permanent ongoing requirement to get Assistant-2 installed.
2019-2-13
DJI Gamora
HedgeTrimmer Posted at 2-13 09:01
I understand about that Captain. This concern about the drivers already escalated from our developers and they working on it to avoid this concern. We apologize for the Inconvenience. Thank you for your consideration.
2019-2-13
Viking-Ger
Disabling Driver Signature Enforcement is in some cases to risky, DJI need to get the drivers officially approved by Microsoft.
A lot of DJI customers having problems and we are not talking about a few dollar toy.
2019-2-13
fansfffeae27
Viking-Ger Posted at 2-13 09:10
Hi.
Im having the same issue, where can I obtain DJI Assistant 2 1.2.2.859 2018_03_09 signedwin7win10.exe from, I also have a phantom 4, so I assume same problem will occur when I wish to upgrade firmware.
Robert
2019-3-1
Viking-Ger
fansfffeae27 Posted at 3-1 19:32
Hi.
Hi Robert,
try this link https://phantompilots.com/thread ... -downgrades.123249/
2019-3-2
