David Moynan
DJI Tony Posted at 1-7 16:27
Hi, thanks for the prompt reply. As of you've mentioned below that you're still getting a live feed on the application, however, the gimbal will not move, right? Did you manage to re-calibrate the gimbal? If yes, I would recommend restoring factory defaults and refresh the firmware of your aircraft using the DJI Assistant 2 to see if there will be changes. You could provide us with a short video about this concern for further help. You may use google drive or dropbox then provide the link here. Please refer to the link below for you to download the application. Thank you.
https://www.dji.com/mavic/downloads
The control pad doesn't recognise the gimbal because when i go into menu and go to gimbal staus N/A comes up beside it . did you ever hear of this before |
