Mark The Droner
Flight distance : 2917 ft
I have read in posts that these are "shielded" bearings which is to say it is possible to lube the bearings if you use the correct oil and if you use a very small amount - much less than a drop. You would apply this miniscule amount of oil to the obvious place near the shaft with an appropriate tool (such as maybe a tooth pick) and allow the oil to "wick" its way into the bearings. However, this is not a recommended procedure and usually unnecessary. I personally have never lubed a motor or had a motor (or ESC for that matter) fail during flight. I have at times heard a minor squeaking sound as I hover before a flight, but I fly anyway and nothing ever happens. If the motor isn't overheated, I would not worry about it. I would not attempt to lube it without an overheating problem because it could potentially attract dirt and create a motor problem whereas before you had no motor problem. MHO.
I think it's likely Labroides was right above and you had metal or iron or something (car keys? cell phone?) interfering with the compass earlier. I also think it's possible your flight controller is bad. In other words, you could have had two problems.
Are you sure you're doing the IMU calibration correctly? That is, are you making sure the AC motors are all perfectly level in all directions before you start the IMU calibration?
When you hover it at eye level, are all four motors perfectly level with each other?
If the answers are yes and no, you probably have a bad FC.
If the answers are yes and not sure, you probably have a bad FC.
Good luck
