JDC93
Flight distance : 1560371 ft
Hi all,
With better weather, I've made my first few flights in some time in the past couple of weeks. After these flights, I have been unable to properly sync my flight records. Prior to the issue, I had 88 flights logged and successfully synced to the cloud. However, after my last three flights, I am unable to complete a total sync of my flight records.
I've tried everything I can think of. I've updated/reinstalled the Go app, I've cleared out cached data, and I've tried to sync on different devices. Nothing works. I've deleted all local flight data, and when I re-sync, I now have 70 flights when I should have 91. Oddly enough, there is no rhyme or reason to the 21 missing flights. All of the most recent flights (which I thought may be causing the issue) are present when I sync. When syncing, the process will reach 90% and then fail. Syncing to 1 and 6 months succeeds, but it does not recover any additional data.
The only thing that has changed with the past few flights is that I've updated battery firmware. I've also experienced compass errors on two of the last three flights (I'm not sure if this would have an effect), but I've since recalibrated.
Does anyone know what may be causing this? Any help is greatly appreciated.
