Eclair29
Flight distance : 306499 ft
Cambodia
Which manual is this from?
For Mavic Air, manual version 1.2 (2018.05) the description is different for 5-20m distance:
"2.b. If the aircraft is between 5m and 20m from the HP, it flies to the HP at the current altitude, unless the current altitude is less than 2.5m, in which case the aircraft ascends to 2.5m and then flies to the HP."
For the Mavic Air, the option "RTH at current altitude" is not described.
Then there is this:
"Failsafe RTH will be automatically activated if the RC signal is lost for a specified amount of time (3 seconds when using the RC, and 20 sec when flying with a mobile device). "
3 seconds is very short to try to re-connect by changing position, readjusting the antennaes, restarting the RC or the app...
Like this post if you wish that 3 second window could be extended! |
