New Osmo Pocket Firmware Released(2019/1/7)
123Next >
18966 91 2019-1-6
djiuser_L6Hnhl3vnAXn
Hi DJI Support.
I've been waiting for the Story mode all along since I got my Osmo Pocket and I was expecting it on the firmware update. Didn't come.
When Should we expect this awesome feature?
Thiago Lopes
2019-1-8
Enzo65
Flight distance : 734485 ft
Was 24fps removed, even from Pro mode???  How can this be?
2019-1-8
djiguy001
DJI Mindy Posted at 1-8 06:22
Hi there, sorry for the troubles on updating the firmware, please restart the APP and Osmo Pocket and then update for three times, if it still fails, the device will need to be sent in for further evaluation.
can you let me know if the 'horizontal' tilt will also be added to the next firmware? because right now - it is difficult to use "only" having vertical up/down tilt, thanks!
2019-1-8
djiuser_izrrMfpzFcZp Posted at 1-8 06:29
Hi Mindy,
I tired many times already still failed, i am taking my osmo pocket to retail store tomorrow.
Sorry for this situation, hope your retail store will help you out.
2019-1-9
djiuser_L6Hnhl3vnAXn Posted at 1-8 08:05
Hi DJI Support.
Hi Thiago Lopes, Story Mode is estimated to be available in the next APP update, thanks for your patience.
2019-1-9
Enzo65 Posted at 1-8 08:08
Hi Enzo, 1080P 25/50fps and 4K 25/50fps resolution have been added to basic settings, the Pro Settings weren't changed, may I have a screenshot of your Pro mode?
2019-1-9
djiguy001 Posted at 1-8 12:27
I'm afraid not, you can purchase Osmo Pocket Controller Wheel which is equipped with a dial for precise pan and tilt control.
2019-1-9
fans81cb94fa
Roger1167 Posted at 1-7 11:39
After fw update not able to use usb c on bottom of op for a wired connection. Can anyone check and see if this is a problem for all op owners. Please
You are correct. The cable I purchased only the other day no longer works
2019-1-9
jaocky chand
India
cricbuzz.com
2019-1-9
djiguy001
DJI Mindy Posted at 1-9 02:08
Can you let me know when it will be added?
Because it is pretty inconvenient having to have the "extra" wheel - especially when it does not fit in the pocket travel case (so need a 'separate' item just to carry the wheel), plus there will be wear & tear if you constantly put it on/off/on/off.
It doesn't seem to make sense why only the veritical tilt would be there, but not the horizontal tilt. Other gimbals such as the removu4k & gopro have it built in...
Can you please request the engineering team include that in the next firmware? Because it is something very important that should be there.
Thanks
2019-1-9
Freak78
Flight distance : 112733 ft
HI DJI Suport,
I am still waiting for the update that prevents the Osmo pockets battery to be drained by my Phone Android.
2019-1-9
djiuser_UFHqfz2ZHdnl
Is there any way to lock exposure without using a phone?
2019-1-9
tejo
Give us d-cinelike as shown in the reviews and ads. I bought it for that ad now it's collecting dust on my desk. I think I might send it back to you...
2019-1-9
tejo
Perfect, you also broke a thing I was using. No more wired connection from the bottom connector. Useless update ever. Damn.
2019-1-9
awulff
Sweden
I really need support for saving 4K footage to iphone 7 plus. I don't even use a computer. I'm transfering the footage to the iphone and edit it on ipad pro.
It can't be that hard, because I can save footage from Filmic pro in 4K to the camera roll.
2019-1-10
Udo13
Flight distance : 257188 ft
awulff Posted at 1-10 01:32
There is another option, though it is a bit awkward but it works. put the sd-card in a memory stick for the iphone and copy the file into the photo-folder. I have done it some times.
https://www.amazon.de/gp/product ... 0?ie=UTF8&psc=1
2019-1-10
Udo13
Udo13 Posted at 1-10 02:31
https://www.amazon.de/gp/product/B01ARQDNFU/ref=ppx_yo_dt_b_asin_title_o04__o00_s00?ie=UTF8&psc=1
What is better 4k 30p or 4k 60p? I create video projects generally in 4k 30p. At 4k 60p one would have more options, e.g. also a small slow motion and thus even more reassurance pans to get
2019-1-10
B_Gears
I have updated to F/W: v01.03.00.20 and the USB-C port works fine. Did you remove the phone adapter that is plugged in just below the window? USB-C port will not work if the phone adapter is in place.
2019-1-10
hedac
I hope for a future update where we can switch to toggle between Basic and Pro modes to have all Pro mode options in the Osmo Pocket if desired. It is very time consuming to have to connect the phone each time you want to go back to Pro mode because it exists Pro mode each time you want to take a photo or do something different and then there is no way to go back to Pro mode unless connecting the phone again. Please put all Pro mode options on the Pocket! Thank you!
2019-1-10
zanve
Flight distance : 2222415 ft
There are things that could still be fixed:
Timelapse in 4k with the ability to enter the Path without connecting it to the phone.
Timelapse with intervals of 0.5 "1" 2 "
Slomotion without that absurd crop.
Pano mode with 2/3 photos, 4 are often too many!
Pano Spherical mode
Possibility to set the pro mode without connecting it to the phone.
2019-1-11
ArmaX
Ukraine
Thanks for great new update!
Just one issue that I noticed in DJI Mimo  iOS app:
I have Bluetooth button on my selfie-stick for iPhone.  It just duplicates "Volume Up" button on iPhone, so I can make photos with built-in camera app just with button, not touching phone display.
Please, can you add this feature to next Mimo APP version? That would be super-useful to start video-shooting or make photo with accessories or Volume Up button, when Osmo Pocket connected to iPhone (same as on iPhone standard camera up). Thanks!
2019-1-11
djiguy001 Posted at 1-9 07:52
I will transfer your need to our engineers for consideration in the future development, thanks for your feedback.
2019-1-11
Freak78 Posted at 1-9 13:33
HI DJI Suport,
Hi Freak78, when the Osmo Pocket is connected to an Android phone by connecting the smartphone adapter, the Osmo Pocket will charge the mobile phone at 5V and 500 mA. This is regulated by the Android Open Accessory (AOA), I'm afraid there is nothing we can do temporarily, to make the Osmo Pocket work longer, it is recommended that the Wireless Module be used.
2019-1-11
djiivan
why the gimbal does not return to the normal position after turn off with the new firmware upgrade? Firmware 01.03.00.20
Does anyone have similar condition?
2019-1-11
djiivan
just link this LINK
2019-1-12
awulff
Sweden
Yes I know. I had to buy a memory card reader. But it’s not a smooth experience to remove the memory card every time. Defeats the purpose of already having the phone connected to the gimbal. It’s not what I expected.
2019-1-12
fansce6d4c4a
awulff Posted at 1-12 01:21
The iPhone will only support an import of 4K 30fps and not 60fps. This isn’t just an Osmo issue, it’s also an issue for other third party cameras including GoPro.
2019-1-12
fans8df2f22f
When will external microphones work?
2019-1-12
fanse55a7666
In the option, you can set a "simple" virtual joystick option and you have pan and tilt separately
2019-1-13
CanonMax
Flight distance : 8953215 ft
tejo Posted at 1-9 22:35
could you please explain a little more what you mean by "no more wired connection... '
I just hooked up my Osmo Pocket to my PC (Windows 10) and I was able to see the content of my SD card...
So maybe I do not understand what you mean...
Thanks!
(Canon)Max
2019-1-14
Freak78
DJI Mindy Posted at 1-11 22:46
Hello,
So DJI knew there was a problem and still released the OSMO Pocket!!!!
It's very bad that DJI takes so long to fix this problem. Android is still used the most in the land of the smartphone.  I feel pitty that DJI is more and more becoming a APPLE ONLY BRAND!!!
The wireless module is not a solution, just a patch and is not out at the moment of speaking. I have placed a order but it comes out 31/1/2019.
There are apps to prevent the Phone from beeing charged by usb-c, but you have to root your phone.
Just make a disable charging via usb-c button in the app!!! Bypass the AOA
2019-1-14
Freak78 Posted at 1-14 15:28
Hello,
We sincerely apologize for the inconvenience caused, it is not what we can optimize immediately, your concern will be forwarded to our engineers, please note the future update.
2019-1-15
fans8df2f22f Posted at 1-12 14:28
Hi there, we are still working on the 3.5mm adapter, we will release in our online store immediately once it is ready, thanks for your patience.
2019-1-15
djiivan Posted at 1-12 00:10
just link this LINK
Hi djiivan,  sorry for the inconvenience caused, we have been aware of this issue and will get it optimized in the next firmware, please wait patiently, thank you.
2019-1-15
awulff
Sweden
fansce6d4c4a Posted at 1-12 10:58
Well, 30 fps does not work for iphone 7 plus. No 4K settings does. That’s the problem. I would be happy with 4K 30 fps.
2019-1-15
Rajaram
India
Can any one clarify if fw  version 1.03.02 is equal to 1.30? Mine after activation on 11.1.19 shows this update. Not 1.30
2019-1-15
djiguy001
fanse55a7666 Posted at 1-13 04:35
where is this 'virtual joystick' you are talking about?
I don't see anything like that... Can you post a screenshot/image?
also - is it a new firmware you've updated?
thanks.
2019-1-15
ZZZZZZ
Flight distance : 78940 ft
Totally agree with zanve. Have time-lapse with shorter intervals and raw images is going to be awesome.
2019-1-18
UweE
Flight distance : 1016775 ft
djiguy001 Posted at 1-15 13:19
it's in the Mimo-app, not on the OP-screen!
2019-1-21
Caacanto
Mexico
Also waiting for the D Cinelike Raw color profile, come on DJI, its one of the reasons I got this awesome camera.
2019-1-21
123Next >
