Ken77
dronie1965 Posted at 1-9 03:11
ok i have done some more testing after the new firmware update and have enclosed an example of the pumping issue in afc mode.
it happens especially before and end of a pan. I also did a test when walking while shooting video and I must admit there you practically can not notice a lot of this pumping focus during moving with the op.
But maybe you could check your own Osmo Pocket while standing still and slide the pan slider to left or right and when stopping you probably or might see the pumping focus. maybe for some it is not an issue but I find it important that you should be able to shoot video without this issue, I think if you make a panning clip , for the time being its better to shoot this part in afs.
I’d agree with this. Although it seems that focus has improved, there is still evidence of focus breathing (pumping) at the beginning and end of pans. In my case, until there is a fix, i shoot with this awareness. So what does that mean? It simply means I may add a couple of extra seconds to the beginning of a pan and edit out the very end of a pan if pumping is evident. Not ideal, but I’m so used to doing workarounds for almost every camera I’ve owned (some costing many multiples of the OP), this is nothing new.
In my case I find it more annoying that EV settings, when in Auto Pro mode, are not retained when the camera is turned off and then back on again. This necessitates me reconnecting the OP to my phone every time I power it back on. |
