AlphaDog
DJI Gamora Posted at 1-9 10:21
Hi there, thank you for the update and sorry to hear about the trouble. If that the case I would recommend to give a try to connect the Aircraft as well on the PC just to check if the Software will recognize it and just to isolate the issue if the cable or the drivers from the computer is the problem. Please keep us posted. Thanks!
Hi
First of all thanks for your reply, I tried several time this morning and at the end it worked out
Connecting the aircraft was not an issue from the beginning, with the remote I solved by connecting it turned off to the pc and than switch it on than off than on again and finally the Assistan2 catches it.
Both zoom and remote are updated to the last version. |
