Osmo pocket split my video into more file 3,80gb
4962 8 2019-1-8
Saverio87
Hi,i recorded video more than 13 minutes and it splits my file to 3 file by it self , I merged all with davinci resolve but I lost some frame video/audio.
How can I solve?
thanks
2019-1-8
Vermifuge
This is a "feature" the older osmo did the same thing.  The Osmo, Osmo Plus and Pocket all cut off around 4.5 - 9 min depending on the format you are using.
2019-1-8
RSW
Flight distance : 116736 ft
It is a limitiation of the file format. FAT has a maximum file size of 4Mb. The device cannot create a file larger than the file system allows.
2019-1-9
Pete84
I found this early on and If you're using 60fps, the audio de-syncs quite a bit, dynamically. So you can't just offset the audio to fix in post.
2019-1-9
mimimomo
New Zealand
RSW Posted at 1-9 09:09
Osmo Pocket uses exFAT that doesn't have the 4GB file limit that FAT32 has, so that's not the reason...
2019-1-9
KerryG
Flight distance : 11736709 ft
MAke sure you format the SD card in the Osmo Pocket
2019-1-9
Saverio87
I have formatted the sd in osmo pocket, the format type is exFat.
I solved it with the join command of the mp4box software.
2019-1-10
Aavalaakso
Flight distance : 328 ft
Finland
What is the easiest way to merge video files to one file? I dont want to open Adobe every time when I store videos where my kids are playing in snow outdoors.
2019-1-11
RSW
mimimomo Posted at 1-9 12:22
It is capable of using exFAT but compatible with FAT32 as well. It all depends on how and where you formatted your card.
2019-1-18
