View/Update Date & Time on Osmo Pocket
8933 30 2019-1-8
PG73
I've had a couple of occasions now where the footage from the OP has the wrong date and time. The first time I believe was because the battery had run down, don't think this was the case the second time as the OP had over 30% battery remaining. I'm assuming the date and time are set by plugging into a phone and retains that information unless the battery runs out? As I can see nowhere in the OP settings to set a date or time, or even just to view that information. There is also no mention of date/time in the manual.
It would be useful to see the date and time on the OP - so I know when filming those details are correct. It would also be useful to be able to update the date and time on the OP itself, in case they're wrong and I don't have my phone (unlikely) or connector (likely) with me.
2019-1-8
GunnarS
Sweden
I have same for video (but never emtied my battery) but it seems to be 1 h before my time and I'm GMT +1 h so I think this cane be the problem. But pics is correct, suspecting a bug.
2019-1-13
PG73
GunnarS Posted at 1-13 02:58
The date on mine went back years (I forget the exact year), so I'm not sure what is choosing the date when that happens.
2019-1-13
Psoon
Flight distance : 16279465 ft
Yes, I think the OS should have a full- time date/time function like all cameras. It should be something that's user accessible
2019-1-13
KleinPhoto
Please tell me we're kidding here, and there is no way to set the Date/Time on the pocket?  I cannot have a device that creates files with an incorrect timestamp for my application... this is critical.  DJI... any help?
2019-3-11
Cloud Surfer
Flight distance : 436391 ft
I'm also having issues where the images captured by Osmo Pocket are all dated Dec 30th 2015. My SD card is brand new and top of the line from Best Buy. I formatted it in the Osmo Pocket and when I noticed the issue I reformatted it in my Macbook Pro. Then I tried the SD card that came from DJI with my accessories pack. No luck. The only difference seems to be when I use the Osmo pocket with my mobile device. The timestamps on the images captured with the Osmo Pocket when it was connected to my mobile device are all correct. Then the images captured right after the mobile device was removed go back to Dec 30th 2015. I love the minimalism of this product and to use it without my phone connected is a must. I look forward to this issue being resolved, hopefully swiftly.
2019-3-30
fansc89cb030
Flight distance : 4006 ft
I am having the same issue for the date and time, every time power off and on, stand-alone shooting, the date will reset to 2016-1-1, so annoying
Only way to do now is plug to the phone for shooting, for correcting the right date and time.
Checked with DJI service center they said it’s firmware problem, Hope next update can fix it.
2019-3-31
Holmes6
Cloud Surfer Posted at 3-30 16:51
I am having the exact same issue, brand new osmo pocket with fw 01.06.00.20
2019-4-3
ayyong
Flight distance : 50335 ft
fansc89cb030 Posted at 3-31 22:18
I have this exact same problem. Brand new Osmo Pocket with up to date firmware.
2019-4-4
ayyong
2019-4-4
djiuser_VbEazerTMWhj
I have exactly the same problem!  When I shot picture/video with OSMO pocket not connected to iPhone, the picture/ video record date will always reset to xxxx 2016!
2019-4-4
2019-4-4
fans5d0e42db
djiuser_VbEazerTMWhj Posted at 4-4 18:32
Yea same problem here ... I absolutely love this cam .. but can’t have this issue with the forage being logged circa 2015 ... whole point of this cam is to not have to connect it up each time to use it... GoPro Hero 7 doesn’t have this problem and has more steaming features .... DJI we need to clean this up !
2019-4-7
Holmes6
I'm guessing that if we could run an earlier firmware the date would be set on the camera and we could upgrade back to the current firmware.  Does anyone have the procedure for firmware downgrade?
2019-4-8
hklin
Problem still there with the latest firmware, when will DJi fix it?
2019-4-8
canon5dm3
Just got a new DJI Osmo Pocket yesterday and upgraded to latest firmware.  All files are showing date stamp of Jan 1, 2016.  Annoying.  I'm connecting with a Pixel 2 XL.
2019-4-9
canon5dm3
canon5dm3 Posted at 4-9 06:04
Just to clarify statement above, I'm shooting in standalone mode, and then connecting to a Pixel 2 XL afterwards.
2019-4-9
snowsummer
Japan
I had the same issue. When I used Osmo Pocket only, the time stamps were in 2015 or 2016. and when I used Osmo Pocket + iPhone, timestamps were correct.
So I formatted SD card when Osmo Pocket + iPhone from iPhone screen. So far timestamps are correct whether I use Osmo Pocket only or w/iPhone.
2019-4-9
snowsummer
Japan
snowsummer Posted at 4-9 17:07
key point here is"So I formatted SD card when Osmo Pocket + iPhone from iPhone screen"
2019-4-9
snowsummer
Japan
snowsummer Posted at 4-9 17:15
Replying to my post...sorry the mess. don know how to delete previous posts...
the issue still exist.
Only solution here is that connecting Osmo to iPhone every time I turn on Osmo, and then disconnect and take pix, vids using Osmo only.
2019-4-9
hklin
Does it means the date will lost once you turn off the Osmo Pocket, even you turn it off for a minute?
2019-4-10
DJDream
Israel
I don't have this issue at all.
I am using the first version of Osmo Pocket ( a little bigger box than the actual colored one).
2019-4-10
snowsummer
Japan
Firmware update 01.06.00.30 fixed this issue!!!
2019-4-12
hklin
Thank you for the fix....
2019-4-13
Oh-no
How long the OP can keep the date/time stamp without connects to Mimo app?
2019-4-13
djiuser_ycIIqDkR1EKS
snowsummer Posted at 4-12 08:42
I doubt if SW updates help this;  I bought mine yesterday (2019/05/12), and upon firing it up, it said a SW update was available, and I updated.  So I presumably have the latest.  My videos are date stamped late-December 2015.
2019-5-12
For mine, the date is late-December 2015 regardless of whether they were recorded connected to my iPhone or not.
2019-5-12
Aha!  Yes, that does seem to have solved the problem, at least based upon one trial.
2019-5-12
djiuser_gW4b5uz8k4Li
I purchased my OSMO Pocket unit Dec 2019 and have upgraded to firmware v01.10.00.30  - This is still an issue.
When the OP is plugged into the phone it records that correct time and date. When the OP is disconnected from the phone, the correct time and date is lost and displays a date from Jan 2016.
I find DJI's lack of response on this issue unacceptable for such a critical and standard feature for video production.
I will be following this up with the Australian Competition and Consumer Commission and DJI support, directly.
2020-1-23
djiuser_ltbL0fzC9ufc
Same thing here. I got this DJI Osmo Pocket in December last year and I just noticed now that all my pictures and videos were all have datestamped of 2016. Annoying and frustrating!!
2021-6-15
Aavalaakso
Flight distance : 328 ft
Finland
There should be manual time set if wanted. I would also like to see this option: overlay timestamp burned in to the video. And maybe also like Pocket 2 has ISO, SS, etc. in subtitles.
Pockets are missing many very tiny and easy to add functions.
2021-6-15
