RedHotPoker
Flight distance : 165105 ft
Well come on in, to the forum...
What you said:
Good afternoon members of the forum, a question on f3a on the suspension. I want to ask what can be? The firmware of the console and the carcass is the last, dji go 3.1.5 rus. Everything works and flies perfectly, but there is one thing that strains a little. When you turn on the drone (as soon as you get it out of the box) everything turns on but the light on the suspension does not light up, it feels like it is heating up separately from the whole of the copter (imu is calibrated at 2-5 degrees, and everything else) if you warm up the suspension from the stove in the car before turning it on, then everything turns on right away and you can fly
Naturally, when a light bulb on a cold one does not burn on a suspension, it is displayed as professional in the ji, and if you warm it up and turn it on, you will immediately see that it is ahead. And everything works and flies as it should.
Newbie only in phantoms. Before this he flew both on different toys and on self-assemblies, and until today I fly on a samobor with a suspension and a camera and there were no problems.
RedHotPoker
