Middle part of video is gone
1447 4 2019-1-9
darrell2
Flight distance : 63632 ft
Ok here it is .Me and the wife was out the other day and i was shooting some video every thing seemed ok when we got home the middle part of the video is gone.It is not on the SD card, Is there away to get it back that is the most important part. I tried doing a search on this but no luck.Can I get that part back it didn't show up no where on tablet or on Dji go it's like it just shut down but I never hit the stop button.
2019-1-9
Mark The Droner
Flight distance : 2917 ft
Middle part?  You mean the second half?  The higher resolution videos have a limit on the DJI systems and when they reach that limit, they close the current video file and start a new video file.  Sounds to me like you likely landed and turned the AC off before you stopped the video recording.  This will result in a corrupted file.  It won't show as a video file.  Hopefully it's still there as a non-descript file.  The fix is to turn the AC on and give it 15 secs or so.  The FW will repair the file for you and close it correctly showing you a working video file.  But if you muck with the SD card w/o giving it a chance to repair, it might be too late to fix.
Good luck.
2019-1-10
darrell2
The first part is there and the last part is there but not the most important part the middle and no I didn't shut the recording off till I landed
2019-1-11
Mark The Droner
You could try a file/disk recovery program but I suspect you'll never recover that file.  Good luck
2019-1-11
Hi darrell2, we are so sorry for what happened, if the video is not in the SD card nor the DJI Go APP, we do not have the official suggestion to recover it, sorry for the inconvenience caused.
2019-1-12
