NIKON D7000 / HDMI
1434 4 2019-1-9
RoBau
Switzerland
Hi Forum Users
We borrowed a Matrice 600 pro to test the compatibility with our camera systems.
Now, are nor sure f the HDMI on the lightbridge2 is working or not, since the hdmi signal form the referece camera (NIKON D7000, set to 1080P60 as output format) not detected by the lightbride2, so video transmission.
The Video LED remains RED solid on the LB2. We updated to the latest fw on both sides (Air and ground unit), link is ok and stable, we did not use the wireless transmitter device, its a direct cable to the LB2, also checked the cable and replaced it.
Is there anything else we could check / test?
Thank you for your feedback.
Best Regards
Roger
2019-1-9
WiSi-Testpilot
Hello Roger,
you may perform some tests:
Check the HDMI settings of the camera, see manual.
Check the Lightbridge with a Gopro for example.
Check the Camera with an HDMI monitor.
I’m using different cameras. The LB is not picky.
Best regards,
Wilhelm
2019-1-9
RoBau
Switzerland
WiSi-Testpilot Posted at 1-9 11:43
Hello Roger,
Hi Wilhelm,
Camera output is working on different HDMI Monitors, set the output to 720P50 to make sure its within the range, also tried 1920p60, same result - nothing, solid red. I also changed the cables, no effect. And finally, the GoPro HDHero3 also is not working, it doesn't even recognize that something is plugged (the LB2 in this case).
I have some nagging doubts that the LB2 HDMI input is defect..
Best Regards
Roger
2019-1-15
RoBau
Switzerland
Hello Roger,
Hi Wilhelm,
Best Regards
Roger
2019-1-15
RoBau
Switzerland
Hello Roger,
Hi Wilhelm,
Best Regards
Roger
2019-1-15
