App not connecting
836 12 2019-1-9
Jdawg21
Flight distance : 248589 ft
Hey guys, I’ve had my Mavic 2 Zoom for a while now but for some reason today I can’t get the DJI GO 4 app to connect to the drone. Drone and the controller is on and cable is connected to my phone but the connection isn’t complete...what do you think I can do or do you think it’s the app not working properly
2019-1-9
DJI Gamora
Hi there, thank you for reaching out and we're sorry to hear about the trouble. With regards to your concern may I ask are you able to connect the Remote to the Aircraft? Make sure first the Remote and Aircraft is connected and on Remote you can give a try to use the Left and Bottom Port just to Isolate the issue. Please keep us posted. Thanks!
2019-1-9
Jdawg21
Yes I tried everything..left port and the back port and no connection
2019-1-9
Jdawg21
I honestly think the app is bugged after the update b/c everything worked before the update
2019-1-9
Ex Machina
Flight distance : 1806362 ft
Jdawg21 Posted at 1-9 10:40
Take a flashlight and shine it into your phone's connection port -- I was having intermittent connection issues until I cleaned all the pocket lint and debris packed into the port, which  made for a flaky connection. Hope this helps!
2019-1-9
Jdawg21
So I managed to get my drone to connect to the controller using the USB port on the back but now my port on the left doesn’t work..help
2019-1-9
DJI Gamora
Jdawg21 Posted at 1-9 13:55
I'm sorry to hear that, can you give a try to charge the remote just to check if there still a connection between the left port from the remote and the USB from the charger brick.
2019-1-9
Jdawg21
Yes the remote still charges in the micro USB port on the left
2019-1-9
ff22
Jdawg21 Posted at 1-9 16:16
Frankly, that is its most important function.  I'd save it solely for charging and use the bottom larger usb port for connection to your device.
2019-1-9
Jdawg21
I used it for connecting my phone to the controller the whole time. I though DJI did that to give it a direct connection instead of WiFi
2019-1-10
DJI Paladin
Flight distance : 318 ft
Jdawg21 Posted at 1-9 10:37
Sorry to hear that. May I know what mobile device and DJI Go 4 app version you are using?   Please back up your files and sync your flight records and then reinstall. You can also try to use a different mobile device or cable so that we can isolate the issue. Thanks for your support.
2019-1-11
Tom Iliffe
Flight distance : 1004 ft
I would try a different OTG cable Maybe a bad connection
2019-1-12
Jdawg21
Tom Iliffe Posted at 1-12 14:41
Yea I tried the OTG cable and still the same result, I’ve been using the bottom usb connection. I’ll just buy a shorter cable so I don’t have it hanging down as much
2019-1-12
