YourLocalPilot
Flight distance : 235735 ft
Gliffy Posted at 1-10 05:41
Try this,
Start with a partially discharged spark battery, put it into position and turn on the charger while its unplugged, this will see if the charger will discharge itself to charge the battery, if it starts charging the spark battery plug in the charger. It should immediately switch from charging the drone battery to charging the charger.
I have tried this it won’t work either. Thanks for your reply though! |
