Wireless Module feedback
12Next >
9757 75 2019-1-9
Curt1591
Thailand
Can't wait for the feedback from those trying the new wireless module. With all the "bugs" perceived with the device itself, we are now tossing in bluetooth!
2019-1-9
Upscaleman
mine arrives tomorrow
2019-1-9
Roger1167
Flight distance : 1510728 ft
Mine arrives Monday. 1/14/19 Let me know what you think upscaleman when you get yours tomorrow. Thanks
2019-1-9
Ken77
Mine arrives Monday too.
2019-1-9
hkphoto.com
received and cannot connect... wtf!!!
2019-1-10
Curt1591
Thailand
hkphoto.com Posted at 1-10 01:49
And, we're off!
2019-1-10
hallmark007
Flight distance : 9827923 ft
Monday......
2019-1-10
hkphoto.com
seem bt is just for pass the wifi pass code?
2019-1-10
edwardyyy
Received this morning. Good but too expensive.
2019-1-10
hallmark007
2019-1-10
hkphoto.com
what a stupid design
2019-1-10
hkphoto.com
Data transfer 4-5MB/s Maybe it is good for table charger and config motion lapse ...
2019-1-10
dewarner
Flight distance : 87536 ft
Can you put in a link for your tripod connector?  Thanks -
2019-1-10
dewarner
2019-1-10
El Diablo
2019-1-10
The Rev
Flight distance : 1256837 ft
hkphoto.com Posted at 1-10 04:46
Does it drain the battery a lot when not connected to the charger?
2019-1-10
hkphoto.com
The Rev Posted at 1-10 06:36
faster but not super fast... need couple more test tomorrow to tell.
2019-1-10
hkphoto.com
the module cannot connect to computer for transfer
2019-1-10
Roger1167
hkphoto.com do you like the module?
2019-1-10
hkphoto.com
Roger1167 Posted at 1-10 08:13
honestly I can live without it. I don't do pro mode setting much and it's not a machine for pro stuffs.
As a cradle... it's not heavy enough, so charging is still more safe inside the original case... no need to worry fall off.
I now give it to my GF because her careless may easy to damage the gimbal if she using OTG to transfer file ;) I will keep using the OTG
People better have it is ... who do more then 2 point motion lapse most of the time.
2019-1-10
Roger1167
Thanks for your input hkphoto.com. Thanks A lot.
2019-1-10
hkphoto.com
it do block the bottom mic ...
2019-1-10
hkphoto.com
you cannot change the wifi password
2019-1-10
Chris1a
Flight distance : 801 ft
Sweden
4-5MB/s transfer speed? And you can't connect it to your desktop over wifi? I do hope this is due to bottlenecks and unfinished stuff. Please don't make us use any DJI proprietary software on the desktops when we get the ability to transfer content wirelessly.
Can you at least set up a 5 point motion lapse, and start recording, wirelessly from the phone, then close mimo when the Osmo Pocket  starts doing its thing? Or does it require the phone to be connected (wirelessly) to the Osmo the whole time while it's doing the motion lapse?
2019-1-10
Curt1591
Thailand
Chris1a Posted at 1-10 14:31
Good question
2019-1-10
j.r.r.
I received my today evening and my first attempts to connect using Wi-Fi and Bluetooth with my Samsung S9 Plus worked perfectly. Base on the video posted in post #10 by hallmark007 there is password needed to connect using Wi-Fi but in my case it connected without me typing 12341234 (default password). It could be because I first tried connecting using Bluetooth, but not sure. The wireless adapter is very tiny, hardly can see/feel when installed on OP. I recorded video in 4K at 30 fps for 10 minutes, my OP started at 84% battery life and after 10 minutes  of recording the battery was at 77%. My Samsung S9 Plus started at 90% battery life and after 10 minutes of recording it went down 89%. Over all very pleased with this accessory, it works very well based on my initial tests. The control of gimbal using cell phone display is bit tricky (wheel control provide much better pan/tilt control), seams like you have to play a bit to get feel of it. When you stop the dragging of gimbal in any direction using the cell phone display and when you stop the movement the gimbal will still travel for second or so before it stops. Is it worth it $59, well in my opinion yes. It works as advertised and more importantly it provides good option to remotely control OP.
2019-1-10
Curt1591
Thailand
Chris1a asked:
"Can you at least set up a 5 point motion lapse, and start recording, wirelessly from the phone, then close mimo when the Osmo Pocket  starts doing its thing?"
I'm hoping for this. I have set up my 1st generation Osmo Mobile, with my GoPro mounted, connecting with my phone, using the DJI Go app. For a test, I set 3 locations, moving the gimbal normally , while monitoring the GoPro's screen. I hit the start button and shut off the phone. It followed the 3 positions. It seems the app programs the gimbal, and that program is stored on the gimbal itself.
I hope this holds true for the Pocket!
2019-1-11
The Rev
Yes you can do everything you can connected with a cable as far as I can see so I’m very pleased with it and you can use it at the same time as the GoPro mount
2019-1-11
The Rev
Curt1591 Posted at 1-11 00:07
Chris1a asked:
Yes it works great for setting up timelapse and can place the OP and sit nice and warm in the car and do the rest in comfort
2019-1-11
hallmark007
The Rev Posted at 1-11 02:57
Thanks for the info, my set arrive on Monday, great it can use mount and Bluetooth module.
2019-1-11
Curt1591
Thailand
The Rev Posted at 1-11 03:01
To be clear, are you saying you can place the OP, set up the motion time lapse, start it, then turn off the app and OP will continue until complete?
2019-1-11
The Rev
You can also playback all the videos you have taken over the wireless connection without any lag so better than my expectations
2019-1-11
The Rev
Curt1591 Posted at 1-11 03:14
Yes just tried that and it works .set up the timelapse with 4 points pressed record then turned the phone off and it just carries on with what it’ was set to do so another plus
2019-1-11
Curt1591
Thailand
The Rev Posted at 1-11 03:19
But, to be clear on your previous post, were you saying you can place the OP, set up the motion time lapse, start it, then turn off the app, shut off the phone, and OP will continue until complete?
2019-1-11
The Rev
Curt1591 Posted at 1-11 03:24
Yes you also have the pro modes and woks the same as if you had physically connected your phone so very pleased as my expectations were not high So definitely exceeded expectations
2019-1-11
janidiver
Croatia
hallmark007 Posted at 1-11 03:12
It is really tinny and is working fine for me.
2019-1-11
janidiver
Croatia
j.r.r. Posted at 1-10 20:21
its working also fine for me..
2019-1-11
bsuicorealtor
Wireless module is horrible! I can’t even get passed 6 feet and it disconnects. Wanted to make Real Estate Home Tours and it’s impossible. A selfie stick works better at the moment.
2019-1-11
Roger1167
My Bluetooth connection is great I was at least 20 feet away and I was controlling the camera on my iPad Pro. Works just like being wired.
2019-1-11
bsuicorealtor
Roger1167 Posted at 1-11 10:50
Mines been choppy when i go 6 feet then it’s gone... i’m gonna try restarting my phone.
2019-1-11
12Next >
